Subject Topic: Connect to SQLAnywhere - Help Post ReplyPost New Topic
Posted: December 02 2017 at 14:19 | IP Logged Quote smarty
Probably not a bug, but rather an issue/corruption with my system....
Periodically I see a "Connect to SQLAnywhere" box pop onto the PH screen. Once this occurs, PH appears to be "hosed".
I suspect something has gotten corrupted. To that end, I have done a "phupg.exe" on my .db file. Still sometimes see the above issue.
I have also noticed that my phlogs.db file is 9,900KB in size. It is much smaller on my other machines (like 2,040 KB). I do an event log trim every 24 hours...no sure why it is growing...
I have made no changes to my pwrhome.ini file (database location, etc.)
Ideas? or possible path forward?
Posted: December 02 2017 at 14:31 | IP Logged Quote smarty
Found this thread:
http://www.power-home.com/forum/forum_posts.asp?TID=3403&KW= phlogs%2Edb
Was able to delete phlogs.db and copied and renamed phlogs10.db to phlogs.db
Hope this fix works...so far so good...
