PowerHome Feature Requests
Subject Topic: Reset 2420M Insteon Motion Sensor Post ReplyPost New Topic
Viper
Posted: January 31 2010 at 12:58 | IP Logged Quote Viper
I'd like to be able to programmatically tell the 2420M to signal the next motion it sees.
Simple description of the scenario is, I have a light that is controlleld by the 2420M. I leave the room and hit the off switch as I leave the room out of habit. I now return to the room in less than 30 seconds with my arms loaded and want the 2420M to turn on the light.
So, the idea is that when I hit the off switch, I have PH wait 2 seconds, then rearm/reset the 2420M so it will again trigger on motion, without waiting for the internal timer of the 2420M to expire.
Having said all that, I have no idea if that can be done with the extended codes or if it is what it is. I'm hoping Dave has some extra knowledge.
Tom
Posted: February 01 2010 at 03:48 | IP Logged Quote grif091
Dave is a magician but in this case I would not expect a solution. The motion sensor RF receiver is turned off to save battery life so it is not listening for a command.
Viper
Posted: February 01 2010 at 07:40 | IP Logged Quote Viper
Lee,
You of course are correct on both items.
I guess my best solution is to make sure I'm using V2 2420Ms so that the delay can be set to 30 seconds instead of 1 minute.
Thanks for the reminder.
Tom
RichardL
Posted: July 26 2010 at 14:17 | IP Logged Quote RichardL
If you set the Motion Sensor to "On-Always" will this issue of "sleeping" for 30 seconds or more go away?
I want to use my motion sensors to ALWAYS send me an "on", even if it is every 2 seconds. I do not need the motion sensor to send an "off".
If I receive an "on" I will turn on a light via a VBS, that VBS will also create a timed event x minutes in the future to turn off that light.
Does anyone know this is how the motion sensor will behave?
Richard
Back to Top View RichardL's Profile Search for other posts by RichardL
