Subject Topic: ph_getitcurl not working...fresh install Post ReplyPost New Topic
Posted: December 17 2015 at 07:24 | IP Logged Quote smarty
...I am going back to Win7 32, Home Premium...
PH formula in question:
ph_getitcurl("http://{IP_TSTAT-LIV}/tstat",5)
Response:
Internal Formula Error
     An internal error occurred while running the formula. Please report
the error details below to PowerHome.
*** Error Details ***
Error Number: 39
Object Name: uo_itc
Class: uo_itc
Routine Name: constructor
Line: 1
Text: Error accessing external object property accesstype at line 1 in
constructor event of object uo_itc.
Note - I had my boot disk crash earlier this week.
I have re-installed Win 7, but now using the 64 bit version (prior was the
32 bit system).
I think I have my PH and the operation system back to the level they
were at prior to the crash.
Edited by smarty - December 21 2015 at 11:03
Posted: December 19 2015 at 18:15 | IP Logged Quote smarty
OK - back to a Win7 32 bit system - full, clean install. All updates done to Win7, and running PH2.1.5d.
Good news is that almost all appears to work...EXCEPT for the ph_getitcurl() function..... (that I use to get information from my Radio thermostats).
Rightly (or wrongly) I did go back and run regsvr32 on
cshtpax6.ocx
csicmax6.ocx
csmsgax6.ocx
csrasax6.ocx
csmtpax6.ocx
cswsvax6.ocx
as mentioned in this post
Link
except that all the files are now zzzzzax8.ocx (version 8 instead of 6?). Still no luck.
I have Win7 32 on my developmental box, and the ph_getitcurl() function works fine there.
I can't find any differences between Windows7, PH or IE11 between the two machines.
What might I be missing?
Posted: January 03 2016 at 20:56 | IP Logged Quote smarty
Anyone?
Posted: January 03 2016 at 21:39 | IP Logged Quote BeachBum
You must have something foreign to PH as I tested your formula and had no problem with win64 bit. Just a stab in the dark but have you run phupg?
Posted: January 04 2016 at 10:53 | IP Logged Quote smarty
Thanks for the suggestion Pete.
Just tried it...database rebuild was uneventful... Rebuilt database still gives me the same error :(
Posted: January 04 2016 at 20:28 | IP Logged Quote dhoward
Steve,
PowerHome 2.1.5d uses the version 8 of the Catalyst
controls zzzzzax8.ocx. However, the ph_getitcurl does
not make use of any of the Catalyst controls and
instead uses the Microsoft Internet Transfer Control
which is file msinet.ocx (should be in
c:\windows\system32 on Windows 7/32). Check to make
sure the file exists and try running regsvr32 on it if
it does.
Let me know how it goes.
Posted: January 05 2016 at 09:32 | IP Logged Quote smarty
    That file is not on my fresh install (anywhere). Very odd. I will copy it from my other machine into system32 and register it. I will let you know how it goes...
Update...
After copying that file off another (older Win 7 x32 machine), and placing in the system32, then registering it....all now works (thank you Dave).
However - that file was NOT natively installed on my Win7 fresh install. Maybe this file will need to be included with new versions of PH?
Edited by smarty - January 05 2016 at 10:55
