        | jonkjon Groupie
          When I try to open the web center from the Control menu
           | Posted: February 10 2016 at 13:58 | IP Logged |   |
 |  within PH 2.1.5c, it fails to open. It gives a 404 error
 but lists the physical path as being at c:\inetpub...
 which is the default for IIS. Is there a setting i'm
 missing? I am using Windows 10.....
 Jon
        | Back to Top |     |
        | jonkjon Groupie
          I also notice that the page error shows
           | Posted: February 10 2016 at 15:16 | IP Logged |   |
 |  http://127.0.0.1:80/ph-cgi/main but I have set port 88
 in the web server setup.....
 I tried turning the web server off and re-initing and
 then turning it back on and re-initing and that didn't
 help. Also, I can access the web server fine from the
 rest of my network and externally. It only seems to be a
 problem from the Control menu item.
 --Jon
        | Back to Top |     |
        | dhoward Admin Group
          Jon,
           | Posted: February 10 2016 at 15:28 | IP Logged |   |
 You just need to set the default home page for the Web Center. It can be anything you want including the default page for the PowerHome webserver.
 This is done by manually editing the pwrhome.ini file. Locate the [Web Center] section and then set the "home" parameter to your desired start page (a reinit or restart may be necessary in order for this to take effect) and you should be good to go.
        | jonkjon Groupie
          Thanks Dave. That did the trick!!
           | Posted: February 10 2016 at 21:50 | IP Logged |   |
 --Jon
        | Back to Top |     |
