        | renard Groupie
          I am looking at strategies to use Arduino micro-computers to support remote (non-Insteon) sensors and incorporating them into the PH Device database using Virtual Devices.  I want to review my proposed architecture with this august body for comments and suggestions.
           | Posted: October 27 2015 at 21:44 | IP Logged |   |
 There are several design objectives:
 1.     Support 1-wire sensors beyond thermometers to include sensors for humidity, soil moisture, solar flux, and other interesting things.
 2.     Support solar-powered devices and Wi-Fi connectivity to not be limited to either grid power or powerline/Insteon-mesh network communication.
 3.     Not compromise security of my household network comprised of nine PCs connected by gigabit Ethernet cabling and a part-time, highly secured Wi-Fi network with long and complex password.  Total IP connected devices in the house are thirty.
 Arduino Uno with the appropriate library provides native 1-wire support as well as USB-serial connectivity and WiFi capability with the appropriate shield.  For network security reasons, I have eliminated as an option a PH network plug-in as that would require imbedding the primary Wi-Fi network password into the Arduino device that could/would be outside the house and subject to theft.  Even using a second Wi-Fi network (except for the solution proposed below) could allow an unintended bridging between the two IP networks by Windows and permit an intruder to connect using the stolen Arduino WiFi network password and gain access to the primary PC network.
 The proposed solution will use a second Wi-Fi network to communicate between an Arduino Master Controller (AMC) and a constellation of Arduino Remote Controllers(ARCs)  that is totally independent of the primary network.  The AMC would communicate with the House Control PC using a USB hardwired to a USB port on the House Control PC and using the COM Control PH functions discussed below.
 PH would communicate with the AMC using a set of standard message formats.  The first format is to initialize the AMC and using a ‘roll-call’ function in the AMC sketch, determine what ARCs are available.  The roll-call function would also be called by the AMC sketch Setup function when the board is powered up.  The roll-call function could be commanded on a periodic basis by PH by sending the proper command to the AMC.
 When the AMC roll-call function is started, the AMC would attempt to communicate in turn with a predefined number of ARCs using a query status command.  ARCs that respond would be noted on an array of valid ARCs in the AMC sketch.  The AMC sketch Loop function would run continuously and poll the identified ARCs in turn on a cycle, perhaps once per minute.
 The ARC sketch Setup function would establish communication with its 1-wire sensor array and await the roll-call from the AMC.  When identified by the AMC roll-call function, the ARC Loop function would periodically poll the 1-wire sensor array and maintain the current value of each 1-wire sensor.  When the AMC sends a data poll to the ARC, it responds back to the AMC with predefined packets with current values for its sensor array.
 The AMC sketch Loop function would decode the packets and send them via to the USB link to PH where the appropriate PH COM function would generate an interrupt that would launch a macro that uses ph_comrecvstring retrieve and various functions to decode the message and put provided value into the Vx.xx.xx Insteon Virtual Device level in the device table using ph_insteonwithret .  All ‘levels’ for that device will need to be translated into a single byte value between 0 and 255 that is appropriate for the sensor.
 Does anyone see a technical problem with the proposed approach, particularly around using Insteon Virtual Devices and the ph_insteonwithret function.  The objective is to have these ‘devices’ report their level value just like a real device.
 Thanks to everyone.
 Terry
        | Back to Top |     |
        | dhoward Admin Group
          Terry,
           | Posted: October 27 2015 at 23:10 | IP Logged |   |
 Based upon your requirements concerning your network,
 I think your proposed solution is probably our best
 option. I would like to say this is a grand vision and
 I would be very interested in hearing how it all turns
 out
  . I don't think anybody has attempted this level of custom hardware integration.
 That said, a couple of suggestions. If you're up for
 creating your own custom sketches and such for the
 arduino's, it probably wouldnt be too difficult for
 you to create a custom plugin to handle the
 communication. This would be alot cleaner and more
 efficient than relying upon the internal COM routines.
 The other thing I would change is using the Insteon
 virtual devices. While this should work for you, I
 think you would have alot more flexibility in using
 virtual Analog I/O devices. The Analog I/O table gives
 you both a "raw" value and a "calculated" value with
 formulas for conversion between the two and would make
 the display of your temperatures, humidity, solar,
 etc. much easier than adapting a virtual Insteon which
 is going to try to display Lighting percentage and on
 or off. The Analog table is what is used for all of
 the "extended" Insteon controls such as the
 thermostats, IOLincs, etc. You could declare a new
 PowerHome Controller of type "PowerHome Virtual" (this
 is just a dummy controller) and an Analog I/O type of
 "Input" or "Output" and then control or "set" the
 virtual device using the ph_setanalogout function. It
 takes a little getting used to if you havent used the
 Analog table before but there are quite a few
 functions that make this great for any type of
 "virtual" device and allows you a much greater range
 of options for Display on the device status screen.
 Hope this helps and let me know how it goes.
        | renard Groupie
          Thanks Dave,
           | Posted: October 29 2015 at 22:20 | IP Logged |   |
 I appreciate the advice and will follow it.  I'll keep everyone updated on my progress.
 Terry
        | Back to Top |     |
