        | RichardL Senior Member
          I have a new IOLinc (2450) that I am trying to set up.
           | Posted: November 12 2015 at 15:39 | IP Logged |   |
 Powerhome recognized it perfectly and has it as a type 2450 - I/O Linc.  I am running v2.1.5c.
 When the IOLinc senses a break in the PhotoBeam I have it hooked up to, the sense light goes green, so we are good there.  But - nothing comes back to Powerhome.  Nothing in the event log, etc.
 I think the issue is I cannot get any device or the PLM to become a responder.  On "Links", for the IOLinc device, I drag the PLM to the responder window it shows the clipboard, asks to save changes, but nothing shows.  The responder window remains empty.  Same for any other device I tried.  The controller window does have the PLM.
 Any ideas/thoughts?
 As usual, thanks in advance for the help.
 Richard
        | Back to Top |     |
        | dhoward Admin Group
          Richard,
           | Posted: November 12 2015 at 19:52 | IP Logged |   |
 You are correct. The problem with getting info back to
 PowerHome for the sensor is that the PLM has not been
 added as a responder.
 However, you're having an issue where you cant add the
 PLM as a responder in the Links tab. Based upon the
 behavior you describe, check the "Types" tab for your
 2450 - I/O Linc device type and make sure that the
 "Resp Groups" column is set to 1. It sounds its set to
 0 which will keep you from creating any responder
 links. The "Ctlr Groups" should also be set to 1.
 After making and saving this change, close and reopen
 the Insteon Explorer and you'll be able to add the PLM
 as a responder.
 After doing this and insuring that you're now getting
 incoming messages, you'll want to create a new device
 type in the Analog I/O table for the photobeam sensor
 so you can get realtime device status and create
 triggers off of this rather than trying to manually
 interpret the Insteon commands yourself.
           | Posted: November 12 2015 at 22:06 | IP Logged |   |
 That was it!  The Resp Groups was a 1, but Ctrl Groups was a 0.  Changing that to a 1 allowed me to add in the PLM as a responder.  I still have to play with the Analog I/O table.
 I will keep everyone posted as to progress with the PhotoBeam signal and trigger responses.
 Your software and support are fantastic!
 Thank you.
 Richard
        | Back to Top |     |
