        | artart Newbie
          Hello, I've been reading the forum to try to figure
           | Posted: April 18 2015 at 16:35 | IP Logged |   |
 |  out how to set up a 1-wire system. I am finding
 conflicting and incomplete information on how this is
 done. I found two different pdf tutorials that use a
 program called LOGTEMP and then import the 1-wire data
 from that into PH. Then I found other posts that seem
 to suggest that LOGTEMP is not needed? Can someone
 give a an overview on how to set up PH to interface
 with a 1-wire network. That would be greatly
 appreciated. Nothing in the documentation or help file
 that I could find.
        | Back to Top |     |
        | artart Newbie
          After a bunch of trial and error and retrial and error
           | Posted: April 19 2015 at 23:53 | IP Logged |   |
 |  I think I have figured it out.
        | Back to Top |     |
        | dhoward Admin Group
          Art,
           | Posted: April 20 2015 at 05:08 | IP Logged |   |
 Sorry to take so long responding but currently in South Korea with limited internet access at times.
 The newest beta's of PowerHome (2.1.5c) include 1-wire support built in so no longer need the LOGTEMP program or importing data. 1-wire devices are added in the Analog I/O table.
 Sounds like you might have it figured out but you can also check the sample database to see how some 1-wire devices are configured. If you need additional help, just let me know.
        | artart Newbie
          Thanks. Where do I find the sample database?
           | Posted: April 20 2015 at 11:20 | IP Logged |   |
        | Back to Top |     |
        | dhoward Admin Group
          art,
           | Posted: April 21 2015 at 02:20 | IP Logged |   |
 To view the sample database(s), open the PowerHome
 Explorer and then press the F7 key (you can also go to
 menu Edit->Database or use the toolbar). In the dialog
 that opens, navigate to c:\powerhome\database and
 you'll see your default database (pwrhome.db) as well
 as a couple of samples (phsample_dwh.db and
 phsample_keb.db). Select the one you want and you'll
 be able to browse the macro's, triggers, devices, etc.
 of that database.
        | artart Newbie
          Thanks Dave.
           | Posted: April 21 2015 at 09:10 | IP Logged |   |
        | Back to Top |     |
        | Lenny Senior Member
          Dave, is there a list of power-home supported 1-wire devices someplace? I have temp sensors but was looking at adding humidity for outdoors. I went to hobby boards site and saw the HT4-R1-A Temp/Humidity sensor. Looking at your sample DB I see you have temp/humidity with the same address, so I'm assuming this is the board you use. However there is a warning now saying it is "a new design and is not compatible with our previous Humidity/Temp".
           | Posted: May 10 2015 at 07:54 | IP Logged |   |
 |  http://www.hobby-boards.com/store/products.php?product=Humid ity{47}Temp
 Any thoughts? Thanks as always.
        | Back to Top |     |
        | dhoward Admin Group
          Lenny,
           | Posted: May 10 2015 at 22:07 | IP Logged |   |
 You are correct that I am using (an older) Hobby-boards temp/humidity sensor. I went to their site and looked at the documentation that they have for their temp/humidity sensor. At this time, it would not be supported by PowerHome as it uses a custom family code that we havent implemented. I'll look into adding it when I return back to the states.
 As far as currently supported devices, I'll post a list of family codes shortly. It'll take me a little bit to look it up since I don't have access to my development machine.
        | dhoward Admin Group
          Lenny,
           | Posted: August 12 2015 at 19:05 | IP Logged |   |
 The PowerHome 1-wire controller currently supports the
 following three (hex) family classes:
 10 - (Temperature - DS18S20 type devices)
 26 - (Temp/Humidity/Barometer/Light - DS2438 type
 devices)
 28 - (Temperature - DS18B20 type devices)
 I can add more upon request. I just don't have sample
 devices to test with though so would have to add the
 code based upon specs.
 Hope this helps and sorry it took so long.
