| dhoward Admin Group
          PowerHome 2.1.5d is now available for download. This is NOT a full release and is a collection of all fixes thus far applied to version 2.1.5c. Normally this would have been called 2.1.5c fix 6 (the 6th collection of fixes) but it was causing confusion with not having the actual version show any different from the original 2.1.5c.
           | Posted: August 15 2015 at 22:05 | IP Logged |   |
 Note that you MUST already have 2.1.5c (with or without previous fixes) installed before you can make use of this file. It is not a full installation and you'll just unzip it into your current PowerHome installation overwriting existing files.
 This release includes fixes to the CPU-XA, Global Cache, Elk, Virtual Serial Port plugin, and the ph_geturl1 function.
 Let me know if you have any issues.
 http://www.power-home.com/download/ph215d.zip
