        | MrGibbage Super User
          My front porch light has all of a sudden started doing something strange. Whenever I turn any other light
           | Posted: September 16 2015 at 05:30 | IP Logged |   |
 |  in the house on or off, the front porch light blinks once or twice. Would this indicate a problem with the
 switch or with the PLM? Or something else? I did some raw captures to see if there were any clues. I turned
 my study light on and off a few times and captured the insteon traffic and the PH logs here.
 Raw Log:
 2015-09-16  04:54:31.851     TX  &nbs p;  02 62 1D 36 B6 0F 13 00
 2015-09-16  04:54:31.911     RX  &nbs p;  SENTINSTEON=14 85 10 1D 36 B6 0F 13 00 06
 2015-09-16  04:54:32.204     RX  &nbs p;  RECEIVEINSTEONRAW=1D  36 B6 14 85 10 2B 13 00
 2015-09-16  04:54:35.591     TX  &nbs p;  02 62 1D 36 B6 0F 11 FF
 2015-09-16  04:54:35.635     RX  &nbs p;  SENTINSTEON=14 85 10 1D 36 B6 0F 11 FF 06
 2015-09-16  04:54:35.928     RX  &nbs p;  RECEIVEINSTEONRAW=1D  36 B6 14 85 10 2B 11 FF
 PH Log:
 INSTEON PLM Controller PLM transmission of Address:[1D.36.B6] Flags:[15] Cmd1:[19] Cmd2:[0].  Decode:
 Direct. ID: STUDY, Off
 Incoming Insteon received on INSTEON PLM controller PLM. From Address:[1D.36.B6] To Address:[14.85.10]
 Flags:[43] Cmd1:[19] Cmd2:[0].  Decode: Direct ACK. From: STUDY To: PLMCTLR1, Off
 INSTEON PLM Controller PLM transmission of Address:[1D.36.B6] Flags:[15] Cmd1:[17] Cmd2:[255].  Decode:
 Direct. ID: STUDY, On
 Flags:[39] Cmd1:[17] Cmd2:[255].  Decode: Direct ACK. From: STUDY To: PLMCTLR1, On
 Flags:[43] Cmd1:[17] Cmd2:[255].  Decode: Direct ACK. From: STUDY To: PLMCTLR1, On
 I don't see any traffic pointing to the front porch light, so it's like it never happened, but it is
 definitely blinking every time I do something.
 Any suggestions?
 Skip
        | Back to Top |     |
        | TonyNo Moderator Group
          Watching this! I have a lamp module doing this now.
           | Posted: September 16 2015 at 07:24 | IP Logged |   |
        | dhoward Admin Group
          Ive had very similar problems happen a couple of times
           | Posted: September 16 2015 at 09:18 | IP Logged |   |
 |  (a switch doing something crazy with Insteon traffic).
 Both times ended up being the switch itself and not the
 PLM.
        | nick7920 Senior Member
          I had similar once or twice both time switch - had to
           | Posted: September 16 2015 at 19:23 | IP Logged |   |
 |  factory reset the switch. some switch also has x10
 address would also check that.
 Nick
        | Back to Top |     |
        | BeachBum Super User
          I also have lamp module 2672-222 Insteon LED doing the same thing. I'll do some trouble shooting and see if I can get closer to the issue.
           | Posted: September 17 2015 at 07:41 | IP Logged |   |
        | Back to Top |     |
