        | MrGibbage Super User
          Didn't the old version have a KPL tab on the Insteon
           | Posted: April 04 2015 at 20:39 | IP Logged |   |
 |  Explorer? I don't see one on 2.1.5, so how do I program a
 2334-222?
 I have the device installed in the wall, and autodiscovery
 found it ok, but it is listed as an XXX - New Insteon
 Device Type on the device tab. Other than that, I don't
 know what else I can do with it.
 Skip
        | Back to Top |     |
        | dhoward Admin Group
          Skip,
           | Posted: April 04 2015 at 22:42 | IP Logged |   |
 Keypadlinc setup moved to a tab in the window that opens
 when you press the "Options" button on the devices tab.
 To correct the XXXX - New Insteon device, just go to the
 "Types" tab and change the newly created entry to match
 the description you would like.
          Thanks. Is there a way to make a PLM group a responder for
           | Posted: April 05 2015 at 08:34 | IP Logged |   |
 |  a KPL button? I tried adding my PLM as a responder, then I
 entered the PLM group ID in the Group column and I
 immediately got an error that I could only put a 1 or a 0
 in that column. This is strange because I have this for one
 of my older KPLs and I did exactly that--I put the PLM
 group number in the first column. So is it something
 different with the new type of KPL? Or am I just doing it
 wrong?
 Skip
        | Back to Top |     |
        | dhoward Admin Group
          Skip,
           | Posted: April 05 2015 at 10:19 | IP Logged |   |
 Yes, you should be able to make the PLM a responder of
 a KPL button with no problem (you definitely want to
 do this as this is PowerHome will "know" that the KPL
 button was pressed). However, most people just set the
 "Button" column (the green column under the Responders
 sectoins) to either 0 or 1 for the PLM as it doesnt
 really do anything for you to use a different PLM
 group (it would in no way "trigger" that PLM group or
 control other devices).
 If its only allowing 0 or 1 for this column, then that
 means that your responder groups for your PLM device
 (Types tab) is only 1 and it should be set to 255
 (both controller and responder groups for the PLM
 should be 255).
 Typically the way you would set this up is to make the
 KPL the "Current device" in the links tab. Next
 drag/drop the PLM to the responders area and set the
 Group to the button number of the KPL the PLM will
 respond to. Set the Button to 1 (or any group from 0
 to 255 once you make the change above). The rest of
 the columns, the defaults are fine. Let the links
 build and then PowerHome will be sent an Insteon
 message when the KPL button is pressed and you can
 then fire triggers, etc.
          I hear ya, but I cannot set the group (the first column) to
           | Posted: April 05 2015 at 10:45 | IP Logged |   |
 |  a number higher than 1.
   http://imgur.com/v6PN79a.png
 I did check the types tab, and both were set to 254. I
 changed it to 255, but it still didn't work. It's the 2414U
 in the screenshot below
   http://imgur.com/impWYpt.png
 Skip
        | Back to Top |     |
        | dhoward Admin Group
          Skip,
           | Posted: April 05 2015 at 13:09 | IP Logged |   |
 The blue column ("Group") in the responders window is
 for the current device, in this case the KPL. You need
 to adjust the Types tab for the KPL to show controller
 and responder groups to 8.
 In your original post, you were asking "Is there a way
 to make a PLM group a responder for a KPL button?" and
 then mentioned "then I entered the PLM group ID in the
 Group column" so I thought you meant the "Button"
 column.
 Just an FYI, the color coding of the columns shows
 which device they belong to. The "Current Device" (the
 KPL in your sample) are all blue columns which means
 that the data belongs to that device. In the
 Controllers section, the blue columns also refer to
 the current device whereas the reddish brown columns
 refer to the controller. In the Responders section,
 the blue columns refer to the current device (so the
 Group button is the KPL group not the PLM group) and
 the green columns belong to the responder device.
          That fixed that problem. Thanks, Dave.
           | Posted: April 05 2015 at 16:19 | IP Logged |   |
 Now I am getting close. I want the middle four
 buttons to do this
 3 (upper left) set group 21 to level 255
 4 (upper right) set group 21 to level 96
 5 (lower left) set group 21 to level 0
 6 (lower right) set group 6 to level 0
 The big top and bottom button work fine controlling the
 load that they are connected to.
 Ideally, I would like the middle four buttons to either
 stay on all the time, or stay off. No toggling or
 anything. Just on all the time or off all the time.
 Edited by MrGibbage - April 05 2015 at 16:22
 Skip
        | Back to Top |     |
          Here's a screenshot of what I have so far.
           | Posted: April 05 2015 at 16:33 | IP Logged |   |
   http://i.imgur.com/fhBBBeZ.png
 Skip
        | Back to Top |     |
        | dhoward Admin Group
          Skip,
           | Posted: April 06 2015 at 21:55 | IP Logged |   |
 Not sure what you're trying to accomplish. If you're
 hoping pressing a KPL button will trigger a PLM group
 to be controlled (button 21 and 6) then it won't work
 and goes back to what I was saying before that there
 really isnt any reason to use a PLM "button" group
 number other than 1. Insteon just doesnt work this
 way. You could setup a PowerHome trigger to monitor
 for the KPL button press and then send a command to
 the PLM to control its group 21 or 6 but there will be
 a delay between the button press and the action taking
 place depending upon how much is going on in PowerHome
 at the moment.
 The proper way to do this is to essentially
 "duplicate" the responders to the PLM group as
 responders to the KPL button press. If your PLM group
 21 controls LIGHT1 and LIGHT2 turning both on at 50%
 (level and ramprate are predefined when you create the
 group and cant be changed via a group command) then
 you would add LIGHT1 and LIGHT2 as responders to the
 KPL group (3 if you want to trigger this group on
 button 3) with the desired ramprate and the level at
 50%.
 You would ALSO want to keep the groups you've defined
 above but change the "button" to 1 so that PowerHome
 will "know" when you press those buttons. You would
 also want to create a PLM responder (again button 1)
 for KPL group 1 (the main button) so PowerHome can
 properly update the status when this button is
 manually controlled.
 To get buttons to only send "on" or "off" commands,
 you would do that in the KPL configuration tab under
 the "Options" button.
          I think I see the error of my ways now.
           | Posted: April 07 2015 at 04:26 | IP Logged |   |
 |  This KPL is outside my master bedroom. I want to be able
 to use it to control the lights in my bedroom. The load
 (button 1) is connected to the hall light, and that's OK.
 It's the middle four buttons that I want to program.
 Buttons 3, 4, & 5 will all control the same lights, but I
 want them at different levels. Those lights have all been
 programmed into PLM group 21. What I am hearing from you
 is that I cannot control the level when I turn the scene
 on. Instead, I will need to make three scenes:
 Bedroom_full_bright (PLM GP21), bedroom_dim (PLM GP22),
 and bedroom_off (PLM GP23). And then I can program each
 of those scenes to the KPL buttons individually.
 I think part of my confusion is that I thought from what
 you were saying earlier is that I thought the GROUP
 column would hold the KPL button number, and the button
 column would hold the PLM group number. That seems
 counter-intuitive, but I can live with it.
 I'll try and redo it tonight after I get home from work.
 Thanks for sticking with me, Dave!
 Skip
        | Back to Top |     |
        | dhoward Admin Group
          Skip,
           | Posted: April 07 2015 at 10:50 | IP Logged |   |
 If I understand you correctly, still not quite right.
 Since you want the KPL buttons to control the lights,
 you don't even need to worry about the PLM (the KPL is
 controlling the lights...not the PLM) so the PLM
 groups and how they are setup are irrelevant.
 If button 3 is to control 2 lights at full on, then in
 the responders for the KPL group 3 (the blue column
 refers to the KPL if it is the current device), create
 two lines. One for LIGHT1 and one for LIGHT2. Set the
 "button" column (the green column will refer to the
 responder device) to both to 1 and set the "D Level"
 to 255 for both. For button 4 (say the lights will be
 turned on at 50%), create two lines (LIGHT1 and
 LIGHT2) and set the "D Level" to 127.
 For each of these responder groups, I would STILL
 include the PLM as a responder (on PLM group 1 which
 would be a 1 in the green "button" column) so that the
 PLM will "know" when you press these buttons so it can
 update status accordingly.
 The Group column in the Responders section (the blue
 column) is the group number for the Current Device
 (which would be the Controller for entries in the
 Responders section) is the Group number of the
 controller. The "Button" column in the Responders
 section (the green column) is the group number for the
 Responder Device.
          Whoo hoo! I am in business now. It's been a long time since
           | Posted: April 07 2015 at 18:17 | IP Logged |   |
 |  I have needed to do any Insteon links and insteon
 programming, so that is why I had all of the questions. For
 the most part, my setup has been rock solid for a few years
 now. So, thanks for putting up with me Dave.
 May I ask another question, then? I am wondering why we
 have PLM groups at all. If I can't set an insteon switch to
 control a PLM group, then why have them? Is it just so PH
 can do stuff with them?
 Skip
        | Back to Top |     |
        | dhoward Admin Group
          Skip,
           | Posted: April 07 2015 at 23:23 | IP Logged |   |
 PLM groups are so you can control (The PLM as a
 controller and various devices as responders) is so
 that the PLM (via PowerHome) can control groups of
 objects together. You have 255 groups available so can
 create all kinds of scenes that PowerHome can launch.
 The PLM should ALWAYS be listed as a responder for all
 devices that are capable of issuing a group command.
 Without the PLM as a responder (remote devices as the
 controller), PowerHome may not know that the remote
 device was remotely controlled.
