| Posted: January 03 2015 at 18:24 | IP Logged
All,
PowerHome version 2.1.5c is now available for download
here: http://www.power-
home.com/download/ph215csetup.exe
See the second post for the changelog.
If you are upgrading from 2.1.5, 2.1.5a, or 2.1.5b
then no need to uninstall, just rename your PowerHome
directory and then install fresh. Copy over your
database and pwrhome.ini files (as well as any others
such as plugin ini files) and you should be good to
go.
If you are upgrading from a version prior to 2.1.5,
see the more detailed upgrade instructions in the
2.1.5 post.
Hopefully this will take of all the issues we had with
2.1.5b.
MD5 for the 2.1.5c download is:
6b4aef68a60cdd27c76d310ecd896b59
**Update - A culmination of all minor fixes is
available here: http://www.power-
home.com/download/ph215d.zip. Just download
and unzip into your PowerHome directory overwriting
any existing files (shutdown PowerHome first of
course). Version will show 2.1.5d when complete. This
is still essentially 2.1.5c with all fixes to date
applied.
Edited by dhoward - August 15 2015 at 21:58
| Posted: January 03 2015 at 18:25 | IP Logged
Changes for 2.1.5c:
Changed 1-wire controller to support an exponential moving average for 1-wire sensor values. The user can choose the number of samples from 1 to 99 by modifying the "Point" column in the Analog I/O screen. Sensors that normally use a value of 0 can now have a value from 101 to 199 with 101 being 1 sample (effectively the same as no averaging) and 199 being 99 samples. For a normal point value of 1 the averaging point values are 201 - 299. Normal point values of 2 have averaging values of 301 - 399.
Changed 1-wire controller to support the "Raw to Calculated" formula column so that adjustments to the calculated value can be performed. This is useful in adding offsets to sensors that don't read properly.
Added bounds checking for the f_char function so that a critical error is prevented. When an out of range parameter is passed, an automessage will now appear along with an entry in the eventlog. The result of the out of bound function will return a 0.
Rewrote the Global Cache socket disconnect detection code and automatic reconnect routines. Also fixed an error that could cause the Global Cache to hang requiring a disconnect/reconnect when an unknown command was sent.
Rewrote the macro messagebox and inputbox routines so that blank parameters will no longer cause a hang or a messagebox that won't go away. Now an automessage error will appear when required parameters are blank.
Corrected a serious bug introduced in version 2.1.5b that prevented links from being created in the Insteon Explorer.
Modified webserver to reverse a change introduced in 2.1.5b that effected the viewport meta tag and how PowerHome webpages are displayed on iphone and android devices.
Corrected problem in PowerHome Explorer that prevented the window from staying maximized and always reverted to a windowed mode.
Added code to prevent a critical error that sometimes occurred in the ue_trayevent executing the OpenIcon function.
Corrected a problem in the PowerHome Remote Control Center application that would cause the system to crash when executed in the non-tab mode and global variables were updated. This also fixes the problem where the wrong data would sometimes be displayed in various global variable fields.
New Plugins:
None
New Functions:
None
Changed Functions:
None
Removed Functions:
None
PWRHOME.INI Changes:
None
Database Changes:
None
gg102 Senior Member
| Posted: January 03 2015 at 19:01 | IP Logged
Nevermind
Edited by gg102 - January 03 2015 at 19:13
| Posted: January 03 2015 at 19:10 | IP Logged
Walt,
Yep, it should be good. It was wrong for about 5 minutes (pointed to 2.1.5b) but has been correct since about 19:30.
nick7920 Senior Member
| Posted: January 06 2015 at 22:23 | IP Logged
after update :
web access information was not copied -
username - password - blacklist (I had long list, will get
it from backup computer).
Socket server information also not copied.
so far I liked the more information in log , thermostat is
showing correct coolsp , will keep an eye on it.
Nick
