| Posted: January 04 2013 at 15:33 | IP Logged
Any idea what is happening here? ARe there some CR/LF's in the auto wrap that are messing this up? It should work....right?
ph_geturl("http://rss.wunderground.com/auto/rss_full/TX/San_ Antonio.xml?units=english")
Gets me this:
Internal Formula Error
An internal error occurred while running the formula. Please report the error details below to PowerHome.
*** Error Details ***
Error Number: 39
Object Name: uo_socketblob
Class: uo_socketblob
Routine Name: f_geturl
Line: 46
Text: Error accessing external object property autoresolve at line 46 in function f_geturl of object uo_socketblob.
| Posted: January 04 2013 at 16:06 | IP Logged
I'm pretty sure it ISN'T a PH snafu....but rather something within Win7 or EI9 (which I am using).
I think this site might only allow you to grab data only XX minutes apart...otherwise i get the above error...
Edited by smarty - January 04 2013 at 19:42
| Posted: January 04 2013 at 22:08 | IP Logged
Smarty,
Just tested it on 2.1.4 here and it worked fine. Based
upon the error message, it would appear that the Catalyst
socket control is not registered (Im pretty sure you use
this already so not sure why that would be).
In any event, try running:
regsvr32 "c:\windows\system32\cswskax6.ocx" (might be
regsvr32 "c:\windows\syswow64\cswskax6.ocx")
Hopefully that will register the control and get you
working.
syonker Senior Member
| Posted: August 02 2014 at 11:39 | IP Logged
Hi Gang,
Just a follow-on note...I noticed my weather macro was
failing the geturl() command with a syntax error and
figured since I had ported PowerHome to 64-bit Windows 7
the last time around this might be the culprit here as
well.
When I tried tried the following to register the OCX, it
failed with the error shown in the screen shot below. I
then tried to launch a Command-Prompt (DOS) with admin
rights by right-clicking and "Run as Administrator".
Nothing happened. Tried again and the command prompt
option didn't work, but everything else was running. I
had to shut down PowerHome...as soon as I did that the
"approve this action" icon came up on the bottom menu bar
and I was able to register the component. Re-launched
PowerHome and tested the macro and it worked fine. Hope
this helps someone down the road. I think the general
point is that:
To "Run as Administrator" on the Command-Prompt (DOS)
window in Windows 7, you have to first shut down
PowerHome.
><(((º>`·.¸¸.·´¯`·.¸><(((º>¸.
