Posted: April 28 2008 at 10:34 | IP Logged
When the controller is the PLM we no longer have the SDM log screen. It would be nice if the Insteon Raw Log in the Insteon Explorer could be pulled out separately and have functions like Save Log and Clear.
Posted: April 28 2008 at 13:34 | IP Logged
I think you could use some SQL to isolate the Insteon activity from the log and export it occasionally.
Posted: April 28 2008 at 15:02 | IP Logged
Thks Tony that’s a good suggestion but I don’t speak SQL. I’m from the old Assembler days.
Posted: April 28 2008 at 17:23 | IP Logged
Well, I could whip something up for ya tonight!
Posted: April 28 2008 at 19:53 | IP Logged
Hey, I'm also an old assembler guy!
This should pull what you need...
select * from eventlog where type=30 or type=31
Posted: April 28 2008 at 20:37 | IP Logged
Thanks Tony but where do I stick it since it doesn’t appear to be PH code? Multi-Editor in SQL ?
Posted: April 28 2008 at 21:18 | IP Logged
Ah, yes. Sorry. Then click on the running man button.
Posted: April 28 2008 at 21:27 | IP Logged
Thanks again, I’ll work on it in the morning. On another note old Assembler like 360 days… And Fortran, Cobol and PL/1. Ancient history… Lee remembers.
Posted: April 29 2008 at 08:24 | IP Logged
That’s cool… I might get dangerous now. BUT what I was really talking about is the Raw data like you see in the Insteon Explorer window.
Posted: April 29 2008 at 11:35 | IP Logged
Ah. Maybe Dave knows of a back door to that, as it's just coming over the serial port.
Posted: May 06 2008 at 12:38 | IP Logged
I'll add the ability to save the PLM log (similar to the SDM lob).
Currently the Insteon Explorer raw log is capped at 1000 entries. Once it reaches 1000, when a new entry is added, the oldest 1 drops off.
Just looking for some ideas on what everyone thinks is the best way to save. A checkbox that enables writes for each entry to a file at the same time as the log or would you rather see a button that allows you to save what is currently in the log window.
Let me know,
Posted: May 06 2008 at 12:44 | IP Logged
I like the file idea then I can edit it to my desire. We would only need to enable it when we are in problem determination mode.
