digby Newbie
Posted: June 01 2012 at 05:41 | IP Logged
I've done experimenting and now in deep. Ordered all my
bits and pieces and it works on a trial basis. It did
crash occasionally, however, only when mucking around
with it.
I've started to fill out the devices (db?) and notice
that it crashes very often (log enclosed from Windows). I
do notice if I click a new entry/field too quick it
crashes but also sometimes it does without notice??
I have read in the forums and have installed it in
C:\PowerHome; Reinstalled Win7 and have no triggers,
turned VR off, changed may computer profile to
performance, run PowerHome as administrator... and
problem remains.
PowerHome log is empty (except for PowerHome System
Startup).
Looking at the windows logs, it appears to be different
detail each time. Here's one:
Faulting application name: pwrhome.exe, version:
1.3.4.11, time stamp: 0x46b148c6
Faulting module name: pbdwe105.dll, version: 10.5.2.7016,
time stamp: 0x46bc2095
Exception code: 0xc0000005
Fault offset: 0x001c7d7f
Faulting process id: 0x58c
Faulting application start time: 0x01cd3fd943d359b5
Faulting application path: C:\powerhome\pwrhome.exe
Faulting module path: C:\Windows\system32\pbdwe105.dll
Report Id: 8671d2ee-abcd-11e1-81a0-002186e388f5
Any ideas?
