Subject Topic: help with ph.run Post ReplyPost New Topic
mustangcoupe
Posted: January 31 2009 at 14:53 | IP Logged Quote mustangcoupe
ok, ive been around a bit ans I still get confused with ' and " ...
can someone help me here... I am sending a command out using the PH.run command to send CID info to all computers on my network.
here is the basics of what I am tring to do...
"C:\Program Files\Windows Home Server\WHSAlert.exe" "Incomming Call" "CID INFO HERE" info 100
ph.run(file name argument1 argument2 argument3 argument4)
file name: C:\Program Files\Windows Home Server\WHSAlert.exe
argument1: Incomming call
argument2: globalvariable {CID}
argument3: info
argument4: 100
each argument needs to be sent in quotes to be processed properly
thanks
Todd Hannemann
HA newbie
   PowerHome - UPB - ELK
jbbtex
Posted: January 31 2009 at 20:18 | IP Logged Quote jbbtex
If you haven't already you might try it like this. I don't use windows script so my example uses ph_run and this is just a guess.
ph_run("'C:\Program Files\Windows Home Server\WHSAlert.exe '" + "'Incomming Call '" + "'" + "{CID}" + "' " + "'info '" + "'100'")
But I'm like you, all the quotes start running together and make my eyes glaze over.
Brady
mustangcoupe
Posted: January 31 2009 at 20:45 | IP Logged Quote mustangcoupe
getting better... I dont get a formula error but I do get a -1 response
Todd Hannemann
HA newbie
jbbtex
Posted: January 31 2009 at 21:34 | IP Logged Quote jbbtex
-1 means there was an error.
Try it by substituting a string for the GV.
ph_run("'C:\Program Files\Windows Home Server\WHSAlert.exe '" + "'Incomming Call '" + "'test string '" + "'info '" + "'100'")
edit: Thought I put this in the first time.
If it does work then we can figure out how to get the variable in.
Edited by jbbtex - February 01 2009 at 03:44
Brady
