Posted: January 13 2009 at 22:46 | IP Logged
OK. I'm stumped. I've been fighting a code failure for half a day and tracked it down to the following:
ph_msgbox("INITIALIZE","ph_getinsteonlevelrt("DWN ROOM")",3)
If I play:
it works correctly and if I play:
ph_msgbox("INITIALIZE","text",3)
it works correctly.
I've tried:
ph_msgbox("INITIALIZE","ph_getinsteonlevelrt("DWN ROOM")",3) and
ph_msgbox("INITIALIZE",ph_getinsteonlevelrt("DWN ROOM"),3) [no quotes on 2nd parameter]
all to no avail. They all fail. BTW "DWN ROOM" is a valid DVC NAME (I tried others just to make sure anyway)
Anybody see why, or is this a bug? Sheesh. So far wasted about 3 hours on this one!
Posted: January 13 2009 at 22:59 | IP Logged
Try...
ph_msgbox("INITIALIZE", string( ph_getinsteonlevelrt( "DWN ROOM")), 3)
ph_getinsteonlevelrt returns a double.
Posted: January 13 2009 at 23:53 | IP Logged
You cannot put a double quoted string inside a double quoted string. Use single quotes around the embedded string. I did not try your statement. Just noting that a double quoted string cannot have an embedded double quoted string.
ph_msgbox("INITIALIZE","ph_getinsteonlevelrt('DWN ROOM')",3)
