Subject Topic: Indirect Addressing Issue Post ReplyPost New Topic
Posted: January 07 2009 at 21:42 | IP Logged Quote GadgetGuy
I've been fighting this all day and can't resolve it, so
hopefully someone can help me figure out what's going
on. It seems like a bug, but I'm not sure.
If I execute the
following:
ph_msgbox("Variables",ph_getglobal_s(ph_
getglobal_s("PAR-FLG")),15)
I get a value of "0" which is what I expect.
ph_getglobal_s("PAR-FLG") returns a value of "SMS1FLAG"
and the double effort (indirect addressing) returns the
value of SMS1FLAG, which is "0".
But when I use this expression as a parameter as in the
following simple example, it does not work.
if(ph_getglobal_s(ph_getglobal_s("PAR-
FLG"))=0,ph_msgbox("Var","0",15),ph_msgbox("Var","1",15)
Attempts to Validate the formula result in "!"
I'm trying to ask if the value of SMS1FLAG=0, then
display a "0" otherwise a "1" but it doesn't work.
If I can get this to work, then hopefully I can get the
real and more complex formula to work!
Any ideas?
Posted: January 07 2009 at 21:59 | IP Logged Quote GadgetGuy
Dang!
I hate it when I solve my own problems!
Discovered that I needed quotes ("") around the "0" in
the IF boolean test.
After struggling with this for 5 hours and a myriad of
various tests, I got to the point where I couldn't tell
what was what anymore. Sometimes a break to pee really
helps to clear the mind!
Posted: January 07 2009 at 22:01 | IP Logged Quote GadgetGuy
GadgetGuy wrote:
Dang!
REALLY points out the need for a User Manual (which
hopefully is in the works).
Posted: January 07 2009 at 22:44 | IP Logged Quote TonyNo
Just so you know, in ph_getglobal_s, the s is for string.
Also, this would work, too.
if( ph_getglobal_n( ph_getglobal_s( "PAR-FLG"))=0, ph_msgbox( "Var", "0", 15), ph_msgbox( "Var", "1", 15))
Your indirection intrigues me! What are you doing?
Posted: January 08 2009 at 11:06 | IP Logged Quote GadgetGuy
Setting up a CC window where I can control how I want to
be notified when Camera Motion is detected. I have
email and SMS choices for each camera and wanted to be
able to enable/disable these flags remotely.
Rather than create a macro for each button press, I
created an Immediate formula for each button's action
that sets a Global Var {BUTTON-STATE} to the Button ID
and then calls a macro to evaluate it.
The macros needs the name (direct) of the state flag
associated with the Button ID but then needs to access
that flag (indirect) to toggle its state. I figured this
was easier than making each button action sequence
determine its button's state before calling a macro.
This allows me to have a single macro that can handle
state toggles for all the buttons on the Control Center.
