Subject Topic: Trigger Tutorial [RESOLVED] Post ReplyPost New Topic
ibscas
Posted: October 21 2008 at 20:24 | IP Logged Quote ibscas
I've been playing around and can't seem to figure out how to get a trigger to fire. I'm sure once I see the mechanics I'll be good, but as a test I'm just trying to fire a macro when a light switch is turned on. I'm in an Insteon environment (mostly). The screen shot is what I came up with but it doesn't do the trick.
I've tried several ways of doing this, I've changed the Trigger Type to be every different kind of Insteon but no luck. In this screen shot I've said (I think) that if ANY Insteon device does ANYTHING then run the macro. Maybe not?
Process flow:
HALL LIGHT SWITCH IS TURNED ON -> Run the macro, which is a 15 second timer to turn it back off again
Pretty simple.
Edited by ibscas - October 22 2008 at 18:51
Back to Top View ibscas's Profile Search for other posts by ibscas
ibscas
Posted: October 21 2008 at 21:14 | IP Logged Quote ibscas
I'm wondering something... I notice that my Insteon screen doesn't seem to be polling anymore - which would certainly mean triggers won't happen. Is there someplace that I might have turned that off?
nadler
Posted: October 21 2008 at 21:27 | IP Logged Quote nadler
That trigger should work. Make sure the light you're
turning on or off is linked to your PLC/PLM otherwise PH
won't be triggered.
Posted: October 21 2008 at 21:28 | IP Logged Quote grif091
Upper left corner of Insteon Explorer, Enable Pending and Status Scan need to be checked for PH to check devices on the Poll Interval time increment.
ibscas
Posted: October 22 2008 at 09:26 | IP Logged Quote ibscas
Both of those are checked, but still no polling. Interestingly, my PH web server stopped working as well, I wonder if they are connected (and yes, there is no firewall running).
Posted: October 22 2008 at 09:32 | IP Logged Quote BeachBum
No red COMMS in Insteon Explorer right?
ibscas
Posted: October 22 2008 at 15:52 | IP Logged Quote ibscas
Only what I would consider as somewhat normal, see screenshot. Everything is working well, actually, just that polling doesn't happen and thus triggers don't fire :(.
ibscas
Posted: October 22 2008 at 16:44 | IP Logged Quote ibscas
To add to my massive screenshot collection, I have taken this one so you can see my settings, etc. As you notice, no polling on the far left window
Posted: October 22 2008 at 17:06 | IP Logged Quote BeachBum
I was referring to the Device Tab. You might also check this post.
http://www.myx10.com/forum/forum_posts.asp?TID=1902&PN=1
ibscas
Posted: October 22 2008 at 18:15 | IP Logged Quote ibscas
I'm taking it then that this is NOT a good thing ? I didn't know what that was supposed to mean when they were red, but I assumed that it hadn't polled it and that's why it was red....
Posted: October 22 2008 at 18:44 | IP Logged Quote grif091
Put a check mark in the Clear Failed column for every device that is shaded. Communication over the powerline was lost at some point for that many devices to be marked as failed. If it comes back, try pulling the plug on your PLM/PLC for a few seconds and then try again.
ibscas
Posted: October 22 2008 at 18:51 | IP Logged Quote ibscas
You ROCK! That fixed it
Thank you, I thought I tried that, but I had done the 'clear comms' instead.
