         traviskleckner Senior Member
           | Posted: January 09 2013 at 11:54 | IP Logged
First, lest this sound critical, let me say I LOVE PH and
 have been using it for > 5 years.  I wouldn't even
 consider my Insteon installation without it.
 That said, will PowerHome ever be able to control some of
 the local settings that it appears HouseLinc can control?
 For example I'd love to be able to set the LED brightness
 from PowerHome.  That's possibly the last missing link
 (or is that linc?) for me.  I find that setting the LED
 brightness on KPLs and SLs to be finicky and very
 annoying (but also critical in bedrooms so as to not make
 the KPL a bright nightlight.)
 I'm currently harboring the fantasy that the switch over
 to I2CS is what's going to make this happen.  Am I right
 to hope that might be the case?
           | Posted: January 09 2013 at 12:55 | IP Logged
Travis,
 Definitely not too critical  .  The plan is to definitely add this functionality where PH will be able to read/modify the extended functions of the available devices such as LED brightness, beep, IOLinc configuration, etc.  Some of this will be available with the 2.1.5 release.  It is independent of I2CS however and unrelated (unless you're specifically dealing with an I2CS device).  It is primarily dependent upon whether the device supports extended (I2) commands or not.  Older switchlincs, kpl's, etc do not support these commands and we'll never be able to modify certain settings within them.
           | Posted: January 09 2013 at 13:00 | IP Logged
That's awesome news.
 I can't wait for 2.1.5!
