        | k2zs Senior Member
          I am suddenly getting an excessive amount of event03 in my
           | Posted: November 11 2011 at 07:34 | IP Logged |   |
 |  reports and certain devices have been sending a larger
 number of NAK's. Nothing new really, is that a sign that I
 should replace the PLM?
 If changing the PLM is recommended should I choose to go
 with a "dual band" device? I'm assuming that other dual
 band devices are required so are there any "repeaters" that
 can be plugged in around the home or would I have to
 replace switches to gain any benefit?
 Scott, K2ZS
 Home Automation Ideas
        | grif091 Super User
          The increase in 03 events and NAKs could indicate a PLC problem.  Could also indicate some issue on the powerline, noisy appliance, UPS attenuating signal, cell phone charger, the list goes on.
           | Posted: November 11 2011 at 09:45 | IP Logged |   |
 The Dual Band PLM alone can act as an interface for RF only devices such as Motion Sensors, TriggerLincs, RemoteLincs, RemoteLinc2s.  If not using Access Points for coupling the 120V phases that could also explain some of the 03 events and NAKs.
        | Back to Top |     |
        | k2zs Senior Member
          Thanks Lee, I think I will be upgrading the PLM soon.
           | Posted: December 02 2011 at 07:39 | IP Logged |   |
 Scott, K2ZS
