        | k2zs Senior Member
          My Electrician is recommending switching to  LED lights
           | Posted: November 29 2011 at 05:10 | IP Logged |   |
 |  due to the number of lamps in the home. We've had to
 replace switches quite often due to the draw caused by
 incandecent lights.
 I guess these new LED lamps are the future replacement of
 CFL's and only draw 10% of the energy. My question is:
 -Has anyone had any experience using LED lights with
 Insteon? Do they work?
 -Are they going to generate any noise on the network that
 may hamper Insteon communication?
 Scott, K2ZS
 Home Automation Ideas
        | Gadgets Senior Member
          I don't know about noise, but they may glow a little even
           | Posted: November 29 2011 at 12:46 | IP Logged |   |
 |  when off. There is a module recommended for LED use but it
 is a outside appliance module. I don't know if there is
 versions for indoor switches and plugs etc.
 Friends, don't let friends install Norton Products
        | dhoward Admin Group
          Scott,
           | Posted: November 29 2011 at 13:51 | IP Logged |   |
 I have a few LED lights controlled by Insteon.  They don't seem to introduce noise (that I can tell) and seem to work fairly well.  The biggest problem I have is dimming even though I bought LED bulbs that are supposed to be dimmable.  They do dim, but anything other than full brightness causes them to flicker or jump back and forth between the current dim setting and something dimmer.  It does this back and forth, not continuously, but every 10 - 15 seconds so dimming is basically unworkable.  Not sure if this is a function of the LED bulb itself or the Insteon 2476D switchlinc that is controlling it.
        | patrickm Senior Member
          I have a few Cree LED lights that are controlled by Insteon dimmers.  They work very well through the dimming range.  My only complaint is their cost (~$40 a lamp).
           | Posted: November 29 2011 at 22:39 | IP Logged |   |
 Patrick
        | Back to Top |     |
        | BwiggleS Newbie
          I question your electrician.  I understand the desire to replace the incandescent bulbs with energy efficient ones, but picking LED over CFL? Compare a 6W bulb from Philips web site of each technology.
           | Posted: December 01 2011 at 07:33 | IP Logged |   |
 |  LED Bulb, 6W, 2700k, 200 lumens, 45000 hours
 CFL Bulb, 5W, 2700k, 215 lumens, 8000 hours
 CFL bulbs are more energy efficient than LED.  CFL bulb costs around $4 while LED costs $28, seven times more.
 7 CFL bulbs at 8000 hours is 56000 hours of run time for the same cost.
 If a bulb averages 4 hours on a day, thats 1400 hours a year so a CFL should last 5.5 years while LED 32 years.
 Also, CFL are available for many different configurations while LED are just coming out.  I have a couple LED bulbs because I just wanted to try them.  They seem to work fine but are not on my insteon devices.  But I won't buy any more until the price becomes more reasonable.
 Brad
        | Back to Top |     |
        | GadgetGuy Super User
          I have changed to LED recessed and ceiling fixture lights
           | Posted: December 01 2011 at 14:39 | IP Logged |   |
 |  almost all over the house. Because I only dim the
 recessed lights a little, they have worked fine with
 Insteon.
 The light bulb replacement LEDs on the ceiling fixtures
 that I like to dim to 15% for night lites did not work.
 It is almost impossible to dim a pure LED that far
 because they are DC devices and on an AC power line they
 need to have rectified DC which usually has a capacitor
 to smooth out the rippling voltage waveform, and the
 small voltage pulse from an Insteon triac dimmer circuit
 is enough to significantly charge the capacitor and light
 the very efficient LED considerably brighter than the
 target 15%.
 I have made everything work perfectly, however, in a two
 bulb fixture by putting a 15W tiny incandescent bulb in
 one socket and the LED bulb in the other.  The
 incandescent bulb helps to absorb the short Insteon
 voltage pulse and "use it up" so the LED doesn't act like
 a white-dwarf star all by itself!
 Edited by GadgetGuy - December 02 2011 at 07:47
 Ken B - Live every day like it's your last.  Eventually, you'll get it right!
        | Back to Top |     |
        | k2zs Senior Member
          Thanks to all for the great feedback...
           | Posted: December 02 2011 at 07:33 | IP Logged |   |
 Scott, K2ZS
