        | smarty Super User
          If any of my Insteon devices have a communications failure, I have a trigger set up that fires the following macro.  This macro sends a text mesage to my phone.  Macro is:
           | Posted: December 16 2011 at 15:36 | IP Logged |   |
 ph_sendsmtpemail("{EMAIL SERVER}",25,"{EMAIL ADDRESS-2}","{EMAIL TXT ADDRESS-1}","[TEMP1]","[TEMP10]")
 Variable [TEMP1] will say "INSTEON COMM FAIL", and variable [TEMP10] will the the insteon address of the failed device (ie 19.47.B9).
 Does any know how I could find insteon "ID" and "Description" corresponding to the insteon address?
 I want my text message to tell me it was "bathroom lts" "load bearing north switch" at address "19.47.B9".
 Edited by smarty - December 16 2011 at 15:37
        | Back to Top |     |
        | JaredM Newbie
          I'd try querying the database directly. Since you said [TEMP10] has the Insteon address, this will get you the device's ID:
           | Posted: December 18 2011 at 01:43 | IP Logged |   |
| Code:
       | ph_sql(0,"select id from insteondevices where Address='[TEMP10]'") |  |  |
 ...and this will get you its description:
| Code:
       | ph_sql(0,"select key_desc from insteondevices where Address='[TEMP10]'") |  |  |  |
        | Back to Top |     |
        | smarty Super User
          Works like a champ....many thanks!
           | Posted: December 18 2011 at 17:20 | IP Logged |   |
        | Back to Top |     |
