ginigma Senior Member
Posted: October 12 2007 at 17:47 | IP Logged
It would be great if you could save a device's config (links) to a file (or DB table). This way, if you want to temporarily use a device for something else, you don't have to enter all the links again. For example, if I have a "roaming" KPL that I want to do different things, in one config I could have one set of lights, and another config could have a completely different setup.
Another use would be if someone wanted to "borrow" a device for a holiday lighting scene, and then put it back to its original location when done.
