Subject Topic: Formal Error Log Post ReplyPost New Topic
Posted: December 09 2008 at 17:21 | IP Logged Quote smarty
Not sure if this is really a bug (since it has no effect on my operation).
When executing the following formula (to convert 24 hr time to 12 hour time); I DO get the desired output text, but I see that I DO generate a formula log error also.
Formula:
string(if(hour(today())>12, hour(today())-12 + ";"+ mid(string(now()),4,2)+" PM", hour(today())+ ";" + mid(string(now()),4,2) + " AM"))
Posted: December 09 2008 at 20:55 | IP Logged Quote TonyNo
I don't see an entry in the log with that.
Which version of PH are you running?
Posted: December 09 2008 at 22:02 | IP Logged Quote dhoward
Smarty,
Not sure why it would give you an error except that you're using the today() function in a couple places when you're probably better off using the now() function.
However, you may find this formula simpler...
string(now(),"hh:mm:ss am/pm")
Check your eventlog settings in the Setup section. There is a new log entry that probably is not default checked when you upgraded that will log an error anytime a formula evaluates with a syntax error.
