GCollins Groupie
Online Status: Offline Posts: 54
Posted: March 09 2015 at 16:49 | IP Logged
Hi PowerHome Experts,
I'd like to have a single macro that runs an automated lighting schedule whenever we are away from home. While that seems like one of the more basic uses for
PowerHome, I haven't seen anything comprehensive posted here. However, I have read discussions of various PH functions and want to apply what I've learned to my
application.
The first part of the scheme uses a trigger to set the value of a global variable {AWAY} to either 1 (true, Elvis has left the building) or 0 (false, he's come back
home).
The second part uses a single timed event to launch the macro. It's set to run daily beginning at some capped Random+ number of minutes after Dusk, conditional on
the value of the {AWAY} variable per this function in the Boolean column: if("{AWAY}"="1", 1, 0)
The third and final part is the macro, which gradually turns various lights on/off over the next few hours leading up to Elvis' normal bedtime. It goes like this:
10 Goto Label if("{AWAY}"="0", "END", "nextLINE") 'Check if system taken out of AWAY mode, break out of macro if so, else fall thru
20 X10 &nb sp; xxx 'Turn some light on or off
30 WAIT &n bsp;1800 + (60 * (ph_random (10))) 'Wait some fixed # of seconds (1800) plus some additional random # of seconds
40 ... &nb sp; &nb sp; &nb sp; &nb sp; 'Ad ditional series of 3 statements like above for different lights and time intervals, and so on
500 LABEL END
As a fairly new PH user I'd appreciate any feedback. Are there any fatal flaws or unexpected negative consequences in this approach? Is there a more efficient way
or better commands to use?
I'm already having trouble getting the Goto Label command to work, which I've posted about in a separate thread. My other concern is with the WAIT command; I've seen
mentioned that the similar DELAY command causes ALL PowerHome processing to pause. I wouldn't want that. It's important that other timed events, macros and triggers
(like Elvis coming home and toggling the Away button) continue to function while this one particular macro is in its various wait states. My testing thus far
indicates it's not a problem, but I just want to be sure.
G
Edited by GCollins - March 09 2015 at 16:52
Posted: March 09 2015 at 17:51 | IP Logged
What I do in this situation is to use Timed Events via a macro called Create Random Events. It generates random on/off times for various lights...
Create Timed Event | FOYER MOTION | string( datetime( today(), relativetime( 00:00:00, [DUSK] + rand( 3600) )))
Create Timed Event | SINK LIGHT OFF | string( datetime( today(), relativetime( 00:00:00, 79200 + rand( 7200) )))
GCollins Groupie
Posted: March 09 2015 at 19:00 | IP Logged
Hi Tony,
That's interesting. If I understand properly, I would
keep a daily repeating event that checks the {AWAY}
variable, and when true would execute a macro that
creates a bunch of one-shot timed events for various
other macros.
Is this a more efficient use of the system versus a
single macro that is stepping slowly though its
commands over the course of a few hours?
Also, how do you cancel the random one-shot events
when the homeowner returns?
Posted: March 09 2015 at 23:38 | IP Logged
GC,
This is basically what I do as well. I have a global
variable such as your AWAY var that is set to 1 when
Im gone and 0 when Im home. A timed event runs daily
that checks the value of this GV (can be done in the
boolean field of the timed event). If conditions are
met and the timed event executes, it launches a macro
to create my random 1 shot timed events.
In my macro, I made a list of all possible items that
I may want to have randomly turned on. I then assigned
a percentage chance of whether that device would
actually get switched for this days random events. If
it does get turned on, I then create a couple of one
shot timed events (one for on, one for off) with
suitable random start/stop time values.
A couple of ways to handle the already created timed
events when the AWAY var changes. I use the
ph_createtimedevent1 function (so I have full control
over the parms). You can include in the boolean
parameter a check for the AWAY var and just leave the
timed events alone as they'll fire (but won't execute)
and then will be gone. The other way you could handle
it is to give all the one shot events a leading prefix
on the ID and then create a trigger on the AWAY var to
run a SQL statement to delete all timedevents with an
ID beginning with the prefix.
GCollins Groupie
Posted: March 10 2015 at 09:36 | IP Logged
OK, that's two valued suggestions to go with the
create timed events approach. I like the percentage
concept and the boolean method for checking the AWAY
var (just like I do when launching the whole thing,
duh).
I will move to this approach, but it's a bit more
complex so I may put it off for a while. Until then,
is there anything terribly wrong with my use of the
WAIT statements as I have it set up now?
Also Dave, would you mind sharing a line of your macro
code that uses the ph_createtimedevent1 function?
Posted: March 11 2015 at 21:35 | IP Logged
G,
You should have no problem using the Wait command. It
won't hold up any PowerHome processing. However, it
will hold up the rest of the macro lines that appear
after the wait (which may be what you want) so your
lights or other "control" statements will be
sequential.
Below is a sample of what a randomly generated timed
event would look like:
In this macro, the first checks whether to skip the
generation of this event. Basically there is an 85%
chance that we will control the KITCHEN light. Line 20
is the creation of the timed event. Im using a random
+/- offset of 40 minutes from the default starttime of
08:00:00. The next parameter (3) is for an action of
Device Control string (this is missing from the help
file). The next line is the event to turn the light
off. Basically you would duplicate these 4 lines over
and over for each light/device you want to randomly
turn on.
Edited by dhoward - March 11 2015 at 21:42
GCollins Groupie
Posted: March 15 2015 at 21:29 | IP Logged
Yes, I want my AWAY events to be sequential (yet at
somewhat random spacing), for now. Mimics our "routine".
Thanks for the peace of mind on the WAIT statement.
Thanks also for the examples, great for the future.
G
