PowerHome Feature Requests
Subject Topic: Vellmen 8055 USB interface Post ReplyPost New Topic
swany
Posted: August 19 2005 at 18:36 | IP Logged Quote swany
Well I don't know if this is even somthing that you would be thinking of but it would be nice. I did not relize that the 8000 was serial and thought this would work. Thats what I get for thinking.
Swany
Back to Top View swany's Profile Search for other posts by swany
Posted: August 19 2005 at 20:12 | IP Logged Quote dhoward
Well...it looks like it would be doable. It appears that they supply a nice DLL for interface communications (unlike the K8000 where I had to write the I2C routines from scratch).
It would be a little ways off however. It would definately be after Insteon, UPB, and CM15A.
So don't rule it out. It looks interesting enough that I'll put it on the to-do list.
swany
Posted: October 17 2006 at 15:31 | IP Logged Quote swany
Dave; just currious if you have given this any more thought?
Swany
Posted: October 17 2006 at 16:11 | IP Logged Quote dhoward
Swany,
I havent gotten anywhere with this yet . I still plan on doing it however, but it would probably end up in Q1 2007.
swany
Posted: October 20 2007 at 14:39 | IP Logged Quote swany
Any yet or still Just wondering..
Swany
Posted: November 05 2007 at 13:38 | IP Logged Quote dhoward
Swany,
Sure missed that date didnt I .
If you've already got this device, I know that an xPL driver is available for it. With the new PowerHome xPL plugin, you should be able to at least control and read this device. The xPL controller is also in the works and will make this much simpler in the next version.
If you've already got an 8055, would it be possible for you test it's operation using the current xPL plugin?
