Subject Topic: help with python Post ReplyPost New Topic
krommetje
Posted: March 16 2016 at 05:24 | IP Logged Quote krommetje
Hi all,
I am working on a raspberry pi to measure temperatures and want
python to send the measurements to ph. I have an examplescript:
I am unable to read multple sensors (DS18b20) for some reason so I
have to connect all 4 sensors to seperate GPIO's....
first I want to make it work with 1 sensor....
import os
import glob
import time
os.system('modprobe w1-gpio')
os.system('modprobe w1-therm')
base_dir = '/sys/bus/w1/devices/'
device_folder = glob.glob(base_dir + '28*')[0]
device_file = device_folder + '/w1_slave'
def read_temp_raw():
    f = open(device_file, 'r')
    lines = f.readlines()
    f.close()
    return lines
def read_temp():
    lines = read_temp_raw()
    while lines[0].strip()[-3:] != 'YES':
        time.sleep(0.2)
    equals_pos = lines[1].find('t=')
    if equals_pos != -1:
        temp_string = lines[1][equals_pos+2:]
        temp_c = float(temp_string) / 1000.0
        temp_f = temp_c * 9.0 / 5.0 + 32.0
        return temp_c, temp_f
while True:
        print(read_temp())
     time.sleep(10)
this code reads gpio4 and takes a temperature measurement every 10
seconds but can be altered for A longer time. Can the code
print(read_temp()
be replaced by a method to send this to ph using
an eval formula e.g or another method? I am a newbie on python so
sorry if the question is "too simple" so to speak....
sorry for the typos
Edited by krommetje - March 16 2016 at 05:26
nick7920
Posted: March 20 2016 at 11:52 | IP Logged Quote nick7920
I dont know much about python but cant you just send
data to PH by web access from it.
just an idea you will have to see how to play with
following have not tried it- look into ph_macroparmret
it will load your data into LOCAL variable and you can
take it from their.
http://testuser:testpass@123.456.789.1 23:5555/ph-
cgi/eval?formula=ph_macroparmret("TEST1",read_temp())
Nick
Posted: March 23 2016 at 15:58 | IP Logged Quote dhoward
Peter,
Never really dabbled with Python so cant offer much
but like Nick says, I would just replace the Python
"Print" statement with whatever the equivalent call is
for Python to make a web call (probably the easiest
way to get data into PowerHome from the Pi).
If the Pi is going to be on the same network as the
PowerHome machine and has access to a shared "drive"
or file location, you could then also just have the Pi
write the value to the shared drive and then use the
PowerHome File Monitor plugin to trigger on a file
change and get the data that way.
