krommetje Super User
Posted: March 12 2008 at 01:12 | IP Logged
Question short and sweet:
Can PH run in Windows Home Server?
jeffw_00 Super User
Posted: March 16 2008 at 14:26 | IP Logged
you can download and try it for 30 days...
mustangcoupe Super User
Posted: April 15 2008 at 17:56 | IP Logged
I know this is a little late but YES. I am running it on WHS.
WHS is basically win2003sbs (small buisness server) stripped down.
you need to have it run as a service but all worked fine for my install.
HA newbie
PowerHome - UPB - ELK
Posted: April 16 2008 at 01:32 | IP Logged
Hey Thanx Mustangcoupe....
I first have to buy a machine capable of running WHS.
What specs do you have? Installation of PH goes local or through the remote software?
Posted: April 16 2008 at 07:10 | IP Logged
Im running a Dell optiplex P4 2.4 GHz 500Gb hd, 1 gb ram
I had an old box laying around once my wife got her laptop so I decided to build my own... I bought the OEM software from newegg.com I have considered replacing it with a 1U rack mount server off ebay for this and just have not gotten around to getting one... I have a second HD to add to it but there is currently a data corruption but and they are in beta with a fix for it. Once they release it I will add the second drive to the drive pool. I am also thinking of making this a sagetv server also.
This is going to be the work horse of my house!
For most of my usage I use remote desktop for most of my matinance as WHS is a truly "headless" operation does not need monitor or keyboard to run... I have one there but don't use it too much.
HA newbie
Posted: April 17 2008 at 10:05 | IP Logged
OK, thanx for the info, my next project will be a WHS running PH so I've got lots of work to do.
The machine that is going to run WHS will be a new one. So i'd have to buy one with Serial and parallel ports equiped with it, going to be hard but i'll find one.
Posted: April 29 2008 at 17:08 | IP Logged
I am having a problem getting the web server to work... I am guessing it is a firewall problem. If you get it let me know what you did. I am still struggeling with it.
HA newbie
QuickCarl2K1 Groupie
Online Status: Offline Posts: 41
Posted: June 06 2011 at 09:27 | IP Logged
you need to have it run as a service but all worked fine for my install. |
Is there some documentation that you can point me to that shows how to install on WHS and run PH2 as a service.
