jostim Groupie
| Posted: August 19 2007 at 11:57 | IP Logged
I have a program I can't get to work. It boils down to the following formula. I added the "ph_rtne (ph_setvar_a (1,1,8)) +" to make it work inside this one formula:
ph_getglobal_s (
"AV CHANNEL " + string ([LOCAL1],"00")
RESULT (from Verify): !
I then make the following change (comment out lines 2 and 4).
/*ph_getglobal_s (*/
RESULT (from Verify):!
Next I ad quotes to [LOCAL1], now I get a result, but I expect the result “AV CHANNEL 08” and I get “AV CHANNEL 00”
"AV CHANNEL " + string ("[LOCAL1]","00")
RESULT (from Verify): AV CHANNEL 00
Now I remove the quotes again and get the result I feel I should get:
RESULT (from Verify):: AV CHANNEL 08
Now I remove the comments from lines 2 and 4
ph_getglobal_s (
RESULT (from Verify): content of [LOCAL1]
YES! It works!
Now I close the formula and open it again, and I am back to square one: RESULT: !.
What am I missing here? Any ideas anyone?
__________________ - jos
| Posted: August 19 2007 at 12:37 | IP Logged
You have a bunch of Globals called "AV CHANNEL xx" and are trying to get their contents?
jostim Groupie
| Posted: August 19 2007 at 17:44 | IP Logged
Exactly.
They are the names and web addresses of radio stations I listen to using Winamp.
I should have explained that better.
- jos
| Posted: August 19 2007 at 17:54 | IP Logged
Try this
| ph_rtne(ph_setvar_a(1, 1, 8)) + ph_getglobal_s( "AV CHANNEL " + string( ph_getvar_n( 1, 1), "00")) |
jostim Groupie
| Posted: August 19 2007 at 22:52 | IP Logged
That did the job.
- jos
