Neptuni Newbie
| Posted: August 31 2007 at 16:04 | IP Logged
Hello,
I would appriciate a little help, I can't get the following VB script to compile in Powerhome.
What am I doing wrong...?
It reports error 1025 on row 2, column 16
Option Explicit
'Declare use of the DLL
Private Declare Function Out8255 Lib "C:\WINDOWS\8255.dll" _
(ByVal PortAddress As Integer, ByVal PortData As Integer) As Integer
Private Declare Function In8255 Lib "8255.dll" _
(ByVal PortAddress As Integer) As Integer
'Declare variables
Dim BaseAddress As Integer: ' 8255 Base Address
Dim Dummy As Integer: ' Dummy variable used with DLL
Dim PortA As Integer: ' 8255 Port A address
Dim PortB As Integer: ' 8255 Port B address
Dim PortC As Integer: ' 8255 Port C address
Dim Cntrl As Integer: ' 8255 Control Address
Private Sub main()
' Assign values for all addresses
BaseAddress = 528
PortA = BaseAddress
PortB = BaseAddress + 1
PortC = BaseAddress + 2
Cntrl = BaseAddress + 3
' configure all ports for output
Dummy = Out8255(Cntrl, 128)
' initialize all Ports to 0
Dummy = Out8255(PortA, 0)
Dummy = Out8255(PortB, 0)
Dummy = Out8255(PortC, 0)
End Sub
Best Regards,
Mikael
Neptuni Newbie
| Posted: September 01 2007 at 18:42 | IP Logged
Ok, I have done some more research...
It should be;
dim Aport instead of;
dim Aport as integer
Is it correct that the use of a dll isn't supported in VBscript?
And if thats true, are there any other way to make use of an dll in PowerHome?
Best Regards,
Mikael
| Posted: September 02 2007 at 20:18 | IP Logged
Mikael,
I am not a VBScript expert, but that is my understanding as well that external DLL's are not supported.
However, look into the new plugin SDK of PowerHome. This will allow you to code in VB (or any language that supports activex creation) and include external DLL's in that plugin as well.
You can find the documentation in the Help file (Help|Contents) as well as full sourcecode samples on the download page.
