cmhardwick Senior Member
| Posted: July 02 2007 at 10:27 | IP Logged
Is there a command, that can be done from another machine, to query the status of devices in the database only and not have to query each device directly?
I know this will be a moot point if I can figure how to use the UDP broadcasts, but for now this would work :)
| Posted: July 02 2007 at 13:28 | IP Logged
IIRC, status queries are against the DB and not the device unless you use the appropriate formula. One of these is ph_getinsteonlevelrt.
| Posted: July 02 2007 at 13:33 | IP Logged
Great. That helps tremendously. Figured it would be you with the answer
