| Posted: July 06 2007 at 11:08 | IP Logged
Is there a way to trigger an event with an X10 ALL OFF.
MrGibbage Super User
| Posted: July 06 2007 at 21:48 | IP Logged
Well, I do this with Insteon:
I set up a trigger to look for a 255 trigger ID Number and a Off 0x13 Trigger ID from a controlinc. Works great.
Skip
| Posted: July 07 2007 at 08:48 | IP Logged
Thanks Skip, I was hoping to find a way with one of my old X10 control boxes with the ALL OFF button. The work around so far is to use an HC/UC from 1 to 16.
| Posted: July 10 2007 at 11:40 | IP Logged
Pete,
If this is incoming X10, then you should be able to do a trigger.
Just use "X-10 In", the House code you interested in, "Any (Before Buffer)", and either "All Units Off" or "All Lights Off".
| Posted: July 10 2007 at 11:52 | IP Logged
Thks Dave.. I didn't know it was hidden in "Any (Before Buffer)".
| Posted: July 10 2007 at 11:53 | IP Logged
Im sneaky like that .
jeremybe Newbie
Online Status: Offline Posts: 39
| Posted: July 10 2007 at 22:38 | IP Logged
On this subject... Is there a way to craete a timed event that sends an X10 house code A all off command? I'm sure it has to be fairly easy to be done, but I cant figure it out..
| Posted: July 10 2007 at 23:40 | IP Logged
This should work.
Create a Timed Event of type Formula and make the formula...
ph_x10( "YourControllerID", "A", 100, 0 )
jeremybe Newbie
| Posted: July 11 2007 at 08:47 | IP Logged
Looks like it worked - Thanks Tony!
