        | krommetje Super User
          Hey all,
           | Posted: March 20 2007 at 03:43 | IP Logged |   |
 perhaps this could be done very easy but I like ideas:
 I have the main PH running on a Pentium4 in my serverroom, I have an old PII laptop on which runs an old PH version in the livingroom, both have a CM11a...
 On the main PHserver there are also Virtual-X10 modules that show temperatures.. How can I send the values of these Virtual-X10 modules to the Laptop in the livingroom so these values appear on the device status?
 one poss. could be using X10 over the powerline and the other could be using the network... which is better and easier?
 any ideas guys?
        | TonyNo Moderator Group
          I would say use the socket server to send ph_devicebtn commands from the main to the secondary with ph_ssrequest. You would then need to set up the socket server on each and create the virtual devices on the secondary system.
           | Posted: March 20 2007 at 06:29 | IP Logged |   |
          For some strange reason I can't send any data with the formula ph_sendsocketdata1("192.168.1.14",8500,1, ....
           | Posted: March 21 2007 at 03:23 | IP Logged |   |
 ERROR... TIME OUT WHILE CONNECTING
 when I use the commandline utility, data is sent OK and received by the other PH.. If I do a ph_run(c:\program files\phsscmd.exe 'ph_setx10stat( .... etc. Then nothing happens also... What am I missing here?
 Edited by krommetje - March 21 2007 at 03:24
          Use ph_ssrequest. ph_sendsocketdata[1] is for raw socket comms.
           | Posted: March 21 2007 at 06:23 | IP Logged |   |
          Will do... be back shortly
           | Posted: March 21 2007 at 23:55 | IP Logged |   |
 (with code this time
          How do I send a ph_X10btn(.. via the ssrequest formula, i tried:
           | Posted: March 25 2007 at 13:31 | IP Logged |   |
| Code:
       | ph_ssrequest("192.168.1.14",8500,"myname","mypass", "FORMULA"," ph_x10btn ( 'B1', 100, round(ABS(case (len (mid("{SENSOR0}",1 ,4)) when 3 then {SENSOR0}/10 when 2 then {SENSOR0} when 1 then {SENSOR0} else {SENSOR0}/100)),0) ")
 and I tried:
| Code:
       | ph_ssrequest('192.168.1.14',8500,'myname','mypass', 'FORMULA','ph_x10btn("B1", 100, ,{curtempa})')
 both fail... Does It has to do with " and ' ?
 and how do I send the dim-value of an X10 device to the other PH?
 Edited by krommetje - March 25 2007 at 13:33
          Another question:
           | Posted: March 26 2007 at 04:20 | IP Logged |   |
 I use this formula to send a Status of an X10-dev. to the other PH:
| Code:
       | ph_ssrequest("192.168.1.14",8500,"krom","krom", "FORMULA",'ph_x10setstat(1, "Q",6 , 100 ,[X10STATQ6])')
 the formula is OK and I get a 0 returned however, the status is not updated in the devicescreen...also when I use a real X10-dev like B1... nothing happens...
 I am stuck here!!!
 Edited by krommetje - March 26 2007 at 04:21
          Wait a minute:
           | Posted: March 26 2007 at 05:15 | IP Logged |   |
 got it!
| Code:
       | ph_ssrequest("192.168.1.14",8500,"myname","mypass", "FORMULA", 'ph_devicebtn( x10, "Q1", adim,"{S3}")')
 For sending an On or Off Status, the same... replace adim and "{S3"} accordingly....
 Edited by krommetje - March 26 2007 at 12:09
          Update:
           | Posted: March 26 2007 at 12:13 | IP Logged |   |
 here is my setup:
 I have a Mailserver, an inbound mailrelay and a backup inbound mailrelay, then i've got 5 temperature readings!
 The status of all servers is checked by ph_ping(... like TonyNo published in an earlier macro, and is sent by ssrequest to the second PH. All temperatures are sent also using dimvalues...
 In all: 8 Virt.X10 mods were added, 5 for dimvalues  and 3 for on/off
