| krommetje Super User
          Hey guys,
           | Posted: October 26 2006 at 06:21 | IP Logged |   |
 I stumbled on a piece of Javascript which enables you to enter data into a form using a Javascript Keypad and I want to use it in a new Touchscreen I am currently saving for:
 for more info here is the link:
 http://www.jtricks.com/javascript/forms/calculator.html
 When I hit the link in the keypad to close the Keypad, I get an error.... when I click the Calc.gif button everything works normal.... At first I didn't get this to work at al but since I hate to give up I took a hard bite and I got it to work...
 (I was biting off more javascript then I could possible chew...)
| Code:
 <center>
 <font face="MS Sans Serif" color=white size=2>Bedlampje Maike:
 <script type="text/javascript"><!--
 /* Script by: www.jtricks.com
 * Version: 20060426
 * Latest version:
 * www.jtricks.com/javascript/forms/calculator.html
 var calc_image = 'calc.gif';
 var calc_start_num = false;
 var calc_cur_oper = '';
 var calc_acc = 0;
 var calc_prev_oper = 0;
 var calc_prev_entry = 0;
 var calc_field;
 function calc_num_value()
 if (calc_field.value == '0.')
 return calc_field.value;
 else if (isNaN(calc_field.value))
 return 0;
 else
 return parseFloat(calc_field.value);
 function calc_perform_oper(oper, val1, val2)
 switch(oper)
 case '*':
 return val1 * val2;
 case '/':
 return val1 / val2;
 case '+':
 return Math.round(
 val1   *  10000000000000 +
 val2   *  10000000000000) /
 100000000000  00;
 case '-':
 return Math.round(
 val1   *  10000000000000 -
 100000000000  00;
 default:
 return val2;
 function calc_press(button)
 switch (button)
 case 'CE':
 calc_start_num = true;
 calc_field.value = "0";
 return;
 case 'C':
 calc_acc = 0;
 calc_cur_oper = "";
 calc_prev_oper = "";
 return;
 case '+/-':
 calc_field.value = calc_num_value() * -1;
 return;
 case ',':
 case '.':
 if (calc_start_num || isNaN(calc_field.value))
 calc_f   ield.value   = "0.";
 calc_s   tart_num   = false;
 else
 if  &nbs p;(calc_field.valu e.indexOf(".")  == -1)
 calc_f ield.value  += ".";
 return;
 case '+':
 case '-':
 case '/':
 case '*':
 calc_prev_oper = button;
 if (calc_start_num)
 calc_c   ur_oper   = button;
 return   ;
 // No break here.
 case '=':
 if (button == '=' && calc_cur_oper != '=')
 calc_p   rev_entry   = calc_num_value();
 if (button == '=' && calc_cur_oper == '=')
 calc_a   cc  = calc_perform_oper(
 calc_p rev_oper, calc_acc, calc_prev_entry)
 else
 calc_c ur_oper , calc_acc, calc_num_value());
 calc_field.value = calc_acc;
 calc_cur_oper = button;
 return;
 if (calc_start_num)
 calc_field.value = button;
 else
 if (calc_num_value() == "0")
 calc_f   ield.value   = button;
 else
 calc_f   ield.value   +=  button;
 function calc_setup(frm, inp)
 if (!document.getElementById)
 return;
 document.write(
 '<a href="javascript:void(0);" ' +
 'onclick="calc_show_hide(\'' +
 frm + '\', \'' + inp +
 '\')"><img style="border:none" ' +
 'src="' + calc_image +
 '"><' + '/a>');
 function move_box(an, box)
 var cleft = 0;
 var ctop = 0;
 var obj = an;
 while (obj.offsetParent)
 cleft += obj.offsetLeft;
 ctop += obj.offsetTop;
 obj = obj.offsetParent;
 box.style.left = cleft + 'px';
 ctop += an.offsetHeight + 2;
 // Handle Internet Explorer body margins,
 // which affect normal document, but not
 // absolute-positioned stuff.
 if (document.body.currentStyle &&
 document.body.currentStyle['marginTop'])
 ctop += parseInt(
 docume   nt.body.curr entStyle  ['marginTop']);
 box.style.top = ctop + 'px';
 function calc_show_hide(frm, inp)
 var boxcalc = document.getElementById('attach_calc_div');
 var to_obj = document.forms[frm].elements[inp];
 if (boxcalc == null)
 return;
 if (to_obj != calc_field ||
 boxcalc.style.display=='none')
 // Show and move calculator.
 move_box(to_obj, boxcalc);
 calc_field = to_obj;
 boxcalc.style.display='block';
 else
 // Hide currently shown calculator.
 boxcalc.style.display='none';
 return false;
 function calc_hide()
 document.getElementById('attach_calc _div')
 .style.display = 'none';
 //--></script>
 <form name="dim" action="/ph-cgi/devicebtn">
 <form method="get" action="/ph-cgi/devicebtn">
 <input type="hidden" name="type" value="0">
 <input type="hidden" name="id" value="M2">
 <input type="submit" name="cmd" value="On" style="background-color:white;border-color:red";>
 <input type="submit" name="cmd" value="Off" style="background-color:white;border-color:red"'>
 <input type="submit" value="ADim" style="background-color:white;border-color:red";>
 <input name="level" type="text" size="5" value="0">
 calc_setup('dim', 'level');
 //--></script>
 <input type="hidden" name="cmd" value="ADim">
 <div id="attach_calc_div"
 style="background:white;padding:2px;border:1px solid #2266AA;position:absolute;display:none">
 <form name="attach_calc_form" action="/ph-cgi/devicebtn"
 style="margin-bottom:0px;margin-top:0px">
 <table style="border:none;padding:0px;border-spacing:0px">
 <tbody>
 <tr><td></td><td></td><td&g t;</td><td></td>
 <td align="center"><a style="font-size:9px;color:#2266AA"
 href="javascript:void(0);" onmouseup="calc_hide()">Close</a></td>
 </tr>
 <tr>
 <td><input style="width:40px" name="cbtn7"
 type="button" value="7" onmouseup="calc_press(7)"></td>
 <td><input style="width:40px" name="cbtn8"
 type="button" value="8" onmouseup="calc_press(8)"></td>
 <td><input style="width:40px" name="cbtn9"
 type="button" value="9" onmouseup="calc_press(9)"></td>
 <td><input style="width:40px" name="cbtnp"
 type="button" value="+" onmouseup="calc_press('+')"></td>
 <td><input style="width:40px" name="cbtnm"
 type="button" value="-" onmouseup="calc_press('-')"></td>
 </tr>
 <tr>
 <td><input style="width:40px" name="cbtn4"
 type="button" value="4" onmouseup="calc_press(4)"></td>
 <td><input style="width:40px" name="cbtn5"
 type="button" value="5" onmouseup="calc_press(5)"></td>
 <td><input style="width:40px" name="cbtn6"
 type="button" value="6" onmouseup="calc_press(6)"></td>
 type="button" value="*" onmouseup="calc_press('*')"></td>
 <td><input style="width:40px" name="cbtnd"
 type="button" value="/" onmouseup="calc_press('/')"></td>
 </tr>
 <tr>
 <td><input style="width:40px" name="cbtn1"
 type="button" value="1" onmouseup="calc_press(1)"></td>
 <td><input style="width:40px" name="cbtn2"
 type="button" value="2" onmouseup="calc_press(2)"></td>
 <td><input style="width:40px" name="cbtn3"
 type="button" value="3" onmouseup="calc_press(3)"></td>
 <td><input style="width:40px" name="cbtnc"
 type="button" value="C" onmouseup="calc_press('C')"></td>
 <td><input style="width:40px" name="cbtne"
 type="button" value="CE" onmouseup="calc_press('CE')"></td>
 </tr>
 <tr>
 <td><input style="width:40px" name="cbtn0"
 type="button" value="0" onmouseup="calc_press(0)"></td>
 type="button" value="." onmouseup="calc_press('.')"></td>
 <td><input style="width:40px" name="cbtnn"
 type="button" value="+/-" onmouseup="calc_press('+/-')"></td>
 <td colspan=2><input style="width:84px" name="cbtnq"
 type="Button" value="=" onmouseup="calc_press('=')"></td>
 </tr>
 </table>
 </form>
 </div>
 <center><font face="MS Sans Serif" color=blue size=2><b>Dimlevel: <font face="MS Sans Serif" color=yellow
 size=2><%int(PH_GETX10LEVEL("M2"))%>
 it took a few days to figure out how it works andf to get it working.... (silly me
  ) The PSP-page works but when I press the calculator link to close the keypad I get an error, can you wizzards out there explain this to me? When I click the calculator button it appears and disappears normally..... for now I have removed the CLOSE link out of the page so to hide the Keypad, the CALC.GIF button has to be clicked again...
 2nd question:
 where should I put the NextUrl Statement?
 Edited by krommetje - October 28 2006 at 09:58
