        | krommetje Super User
          Dave!!
           | Posted: June 08 2006 at 05:08 | IP Logged |   |
 since the new version I am getting a DirectSQL-error 41 in the status request formula:
 ph_rtne(ph_directsql("update x10unitcode set status = 0 where id = 'K' and code = 6") + ph_x10refreshstat() + ph_x10("X10-1","K",6,0) + ph_x10("X10-1","K",15,0))
 The report is:
 X10unitcode not found...
        | dhoward Admin Group
          Peter,
           | Posted: June 11 2006 at 22:44 | IP Logged |   |
 The x10unitcode table went away in the 1.03.4.7 version.  The x10housecode and x10unitcode tables were combined into the x10devices table.  You could do a "select * from x10devices" in the SQL Editor to get a list of the columns and such.
 As a quick fix to your formula, I would think it would look like:
 ph_rtne(ph_directsql("update x10devices set status = 0 where house = 'K' and unit = 6") + ph_x10refreshstat() + ph_x10("X10-1","K",6,0) + ph_x10("X10-1","K",15,0))
