         NorthernAl Groupie
           | Posted: January 30 2010 at 23:50 | IP Logged
Thanks for user id/pwd explanation.  Blank user id and password worked in previous release. Uses guest in PH.
 I entered the master id and password into iHome and that fixed it.  Not sure what changed from last release to this one.
 So I am back running.  Thanks
 Al
         k2zs Senior Member
 Online Status: Offline Posts: 113
           | Posted: January 31 2010 at 08:02 | IP Logged
 I use an external IP address so I can demo the app and found I had to drop the http:// and just use www. for it to work. I believe the old version was the same.
kev21986 wrote:
NorthernAl wrote:
       I also deleted the app and then reinstalled it. No longer crashes.
 Lost all the buttons and settings of course and now trying to set it back up.
 Did the handling of the server url change in this version? I can no longer get iHome to connect to the server. I am using an ip address and port.
 If I enter "http://192.168.0.2:8000" in the server url I cannot connect via the Test Safari link or via iHome. The address in the safari session is "http://(null):(nul)@http://192.168.0.2:8000" which does not connect.
 If I enter "192.168.0.2:8000" the Test in Safari works.  The address in the safari session is "http://(null):(nul)@192.168.0.2:8000". This works in safari although looks weird. I remember early iHome version did something similar. So with this address given by iHome I can connect to my PH server correct.
 But while this address works in Safari iHome does not connect. Nothing in PH log when attempt to connect from iHome.
 Ideas?
 Al
 The URL in Safari is made up of 3 parts (http://[username]:[password]@[server]). The "(null)" is because the fields were left blank. I have never tested the app without a username and password so that may be the issue. Try setting up a username and password in PowerHome and see if that fixes the problem. Once we figure it out I'll send another update out. |
  __________________ Scott, K2ZS
 Home Automation Ideas
         kev21986 Senior Member
 Online Status: Offline Posts: 199
           | Posted: February 01 2010 at 10:13 | IP Logged
 I didn't change anything in that portion of the app so I am not sure why it worked before and doesn't work now. Either way I will fix it to work without a username and password and resubmit the app tonight.
 That is correct. The server URL can be an IP address or domain name. I have a subdomain of invisionsta.com pointed to my PH server. The "http://" is not needed and must be left out.
 Has anyone else had upgrading problems? I would like to get it fixed and submitted to the app store.
  __________________ Kevin Smith
 @respectTheCode
         jpcurcio Senior Member
           | Posted: February 01 2010 at 13:21 | IP Logged
kev21986 wrote:
NorthernAl wrote:
       Has anybody tried
 the update?  I got it this aft.
 After the update, I lost all my buttons and when I tried
 to Edit and setup new buttons the application crashes -
 returns me to Iphone screen.
 I tried powering down my iphone and backup but that did
 not help.
 So my iHome is toast - can't use it at all.  Any
 suggestions on how to recover?
 Sounds like a problem with the database. When you run the
 updated app the first time it upgrades the database to
 add space to store some extra information. It sounds like
 that update failed and left the database unusable. To
 recover from this you will need to delete the app and
 reinstall it.
 I will look into the bug. Has anyone else had this
 problem? |
 Yes, I downloaded the app on Saturday and ran into the
 same issue.  I lost all my buttons.
         k2zs Senior Member
           | Posted: February 01 2010 at 18:17 | IP Logged
Loosing buttons is a given with this update... Thats to be expected when making changes to the structure of a database of this type.
 A tip for re-creating your buttons would be to proto type all of your buttons in PowerHome. I do it in the "Formula" section. When I have them all running the way I would expect I copy the formulas into an email and send it to myself on the iPhone. Then you can copy the formuls from the email and paste it into the button.
 You will have buttons again as well as a back-up copy for future reference in your PowerHome.
         ifjohnnycalls Newbie
           | Posted: February 02 2010 at 10:02 | IP Logged
jpcurcio wrote:
kev21986 wrote:
NorthernAl wrote:
       Has anybody tried
 not help.
 reinstall it.
 problem? |
 same issue.  I lost all my buttons. |
 Same problem here, app crashes when I try to edit buttons.
           | Posted: February 02 2010 at 20:21 | IP Logged
I am looking into a way to fix the database problem. Until I figure that one out I just submitted an update that will allow you to use iHome without a username and password setup in PowerHome. Apple is saying the average app update gets approved in 6 days and thats about what the last one took.
 iHome 2.0 has been put on hold while I figure out what I want to do with the iPad. I have a few new ideas that should work really well on both and give you a lot more options.
 @respectTheCode
         doctorjerry Groupie
           | Posted: February 08 2010 at 01:18 | IP Logged
I am having a problem getting the program to work. I can connect to powerhome through Safari as a test, but I haven't been able to get a button to work.
 With an Insteon device named "study" how do I create a button to simply turn it on and off?
 Jerome
  __________________ Jerome
           | Posted: February 08 2010 at 09:02 | IP Logged
 Jerome |
 You would need to add a button and use "INSTEON+study" as the formula.
 If you want to control a group use "INSTEONGROUP+groupName".
 @respectTheCode
         doctorjerry Groupie
           | Posted: February 08 2010 at 23:02 | IP Logged
I entered INSTEON+STUDY without quotes in the formula.
 Nothing.
           | Posted: February 09 2010 at 16:38 | IP Logged
 Nothing.
 What mode type of button do you have it set as?
 Is PowerHome showing the http request or an error?
 @respectTheCode
         doctorjerry Groupie
           | Posted: February 10 2010 at 09:19 | IP Logged
I'm making progress Kevin. Have patience with me.
 1. I wasn't using a username/password for web access. Now I
 do and iHome communicates with Powerhome.
 2. INSTEON+STUDY works as I imagine it should. Toggles the
 lamp module and changes Icon color to indicate on/off
 state.
 3. INSTEON+ENTER will only only turn on the modules within
 the group. It will not turn them off. The icon color does
 not change with on/off state. In the edit window I can
 toggle the entire group using Control:On/Off.
         k2zs Senior Member
           | Posted: February 10 2010 at 12:42 | IP Logged
It sounds like you have it now. Here is an example of how I use groups and have a button that shows the status of the group. I'm sure there are other ways of doing it so hopefully someone might chime in.
 In my case I have multiple devices in my living room and multiple groups for different scenes. There is one device common to all groups - "L_LIVNG_RM_LAMP". I have button 1 defined as "INSTEON+L_LIVNG_RM_LAMP". This turns the living room lamp on and off.
 Button 2 is defined as a formula that tests for the level of the living room lamp. It uses a case statement that determines in real time what command the button will send. In my case the group "LIVING_RM_FADE" sets the lamp to a level of 167 so that is what I test for
 Example:
 LIVING RM FADE TOGGLE: BUTTON 2
 case(ph_getinsteonlevel( "L_LIVNG_RM_LAMP" ) when 167 then (
 ph_insteongroup ( "LIVING_RM", 17, 1 )
 ) else (
 ph_insteongroup ( "LIVING_RM_FADE", 17, 1 )
 The group "LIVING_RM" is all devices at the normal level. What you end up with is the ability to set two different scenes for a room and have button 1 show the dimmed level of the room.
 state.
 toggle the entire group using Control:On/Off. |
         doctorjerry Groupie
           | Posted: February 10 2010 at 22:03 | IP Logged
Thanks Scott, but your formula goes a bit over my head.
 I sure do hope some others chime in with formula
 examples. Or I'll have to wait for the manual.
 Jerry
           | Posted: February 10 2010 at 22:16 | IP Logged
 Jerry
 Sorry for the long response time. Here is how I have mine set up.
 For every light I have a group with the light and all of the KPL buttons. Turning the group on and off will get the light and all of the KPL buttons. Then in iHome I add a button and use the formula for the light (ie. INSTEON+ENTRY). Then I change the type to custom and change the on and off formulas to control the group instead of the light (ie. ph_devicecontrol("INSTEONGROUP+ENTRY_GROUP+ON")).
 Also the 1.1.1 update that was approved a few days ago fixes the problem with not setting a username and password.
 @respectTheCode
         doctorjerry Groupie
           | Posted: February 11 2010 at 00:16 | IP Logged
I got it now Kevin. I didn't realize what "custom" was
 doing.
 So you can use On/Off to set up a lamp as a "marker" and
 use custom to change how the marker is controlled. Is there
 a limitation to what you can change in the on, off and
 status formulas?
 What is the formula type used for?
 Jerry
           | Posted: February 11 2010 at 02:17 | IP Logged
 doing.
 status formulas?
 Jerry |
 The only limitation is that it must be less than 255 characters.
 @respectTheCode
           | Posted: February 18 2010 at 09:36 | IP Logged
I started a new thread for iHome 2.0 and have a question for you guys.
  http://www.power-home.com/forum/forum_posts.asp?TID=2480&PN= 1
 @respectTheCode
