         patrickm Senior Member
           | Posted: January 15 2010 at 12:25 | IP Logged
Hello,
 Is there any way of customizing the PH Status window sizing?
 I would like to resize the System status window and decrease the Event log pane.  I can manually resize and move the windows but the changes are lost if its closed or PH is reinit.
 Any ideas?
           | Posted: January 15 2010 at 12:56 | IP Logged
Right click on the actual window and select save from the pop-up.
           | Posted: January 15 2010 at 18:32 | IP Logged
thanks very much
         jmarcus25 Newbie
           | Posted: February 14 2010 at 02:29 | IP Logged
It would be great if you could save all the window pane positions so they would load every time.
           | Posted: February 14 2010 at 09:51 | IP Logged
Unless I don’t understand all mine do.
         jmarcus25 Newbie
           | Posted: February 22 2010 at 11:55 | IP Logged
The only pane that comes back up for me is the Device Status pane.
           | Posted: February 22 2010 at 12:05 | IP Logged
In the PowerHome Status screen you have System Status, Time Info Waiting Macros Event Log, Execution Queue, and Incoming Communication Queue. All of these have a save function using your right mouse button. The main window itself on mine always returns to my last sizing.
 Now if you are referring to when you start and the window isn’t there then that can be accomplished in the startup doing a "{alt+F8}"
