         MrGibbage Super User
           | Posted: January 24 2010 at 22:54 | IP Logged
I have the following setup:
 USB-UIRT
 Harmony 620 Remote
 Next Generation Remote extender (http://www.fadfusion.com/selection.php?
 product_item_number=20027000871)
 I am trying to get PH to control my lighting.  So I added a few devices in
 the Harmony software to my 620 to be used just for lighting.  These devices
 are ones that I no longer use, but still have the remote.  I have added
 several over the last few days with the thought that maybe I would have
 better luck with different devices.  Once I find the right device, I
 suspect I will be able to delete the ones that didn't work.
 I have added the devices in the IR Equipment page, and have learned in the
 commands.  When I press a button  on the remote, I can see the status bar
 change with the code.  PH is getting the commands.  Now, here's where it
 gets weird.  When I use my harmony, each time I press the button, I see a
 different code in the status bar.  But if I use the original remote, then I
 consistently get the same code each time, thus allowing my triggers to fire
 correctly.
 So, it would seem that I have it isolated to the harmony itself.  My
 question to you all is, what combination of equipment are you using that
 seems to work correctly with 99%+ accuracy?  If I need a new remote, that's
 fine, but I need to know which one to get.  Or if there's a way to make
 mine work, but perhaps I am missing a crucial setting, or maybe there is a
 magic device out there that will work consistently with my remote, and I
 just need to add it.
 Any ideas?
           | Posted: January 24 2010 at 23:25 | IP Logged
I forgot to mention, it could also be the remote extender
 that is the culprit here.  If I disable the remote
 extender, I can use the harmony.  So somehow it is the
 combination of those two devices.  *sigh*
 I have ordered some of the USB extenders over cat5 adapters
 (yes, I know they are only USB 1.1 compliant, but I just
 want to give that a shot too).  Maybe they will work and
 solve everything.
 Skip
         nadler Super User
           | Posted: January 25 2010 at 08:15 | IP Logged
I use a harmony 680 and a USB UIRT.  I have an IR
 extender that I use in my bedroom hardwired to the
 basement and than use a hardwired IR emitter that I glued
 to the front of the USB IRT located in near the main
 computer in another room at the other end of the house.
 I did this a number of years ago so the following info
 may not be complete, but I suggest that you have PH learn
 the harmony's remote control code not the original
 remote's code.  I recall that I noticed the harmony sent
 (or the USB-UIRT) picked up different codes from the same
 harmony button depending on the distance it was held from
 the USB-UIRT.  So I tried lots of combinations, watched
 the  PH log and used the code that came up the most
 times.  It is about 99.9% reliable and I have been using
 it for years.
 Noel
           | Posted: January 25 2010 at 08:52 | IP Logged
Noel, what IR extender are you using?
           | Posted: January 25 2010 at 10:18 | IP Logged
I use an IR over Coax (Xantech 17294 Xtra Link 2) with mine if that helps.
