         MrGibbage Super User
           | Posted: January 28 2010 at 15:11 | IP Logged
It looks like the real Power Programmers here like to use
 the direct SQL commands to get things done.  Sounds like a
 good idea to me, and I think it will simplify a lot of my
 macros.  Is there a list of tables somewhere that PH uses?
 I think I can figure out what to do from there.
           | Posted: January 28 2010 at 19:00 | IP Logged
The following link to a very old post may provide some of the information you are looking for.  I am afraid that what you attribute to Power Programmers is really just the export of a Macro definition.
 Powerhome Database
         device Newbie
           | Posted: February 01 2010 at 16:29 | IP Logged
Here is the first VBScript I ever wrote which will answer your question. It writes all tables, columns and column types out to a file. I have stuck with VBScript to do all the progammatic work because the environment while new to me then was more familiar. Maybe you will find this useful in enumerating all tables and columns for SQL manipulation.
 D
 Function enumtables()
      On Error Resume Next
     enumtables = "failed"
      Set fso = CreateObject("Scripting.FileSystemObject")
      Set tableinfo = fso.CreateTextFile("c:\Program Files\powerhome\tables.txt", True)
      Set fso = Nothing
      sysstatus = ph.sqlselect(1, "SELECT * FROM sys.syscatalog")
      If (sysstatus = 0) Then
              enumtables = "success"
              tablecount = ph.getsqlrows(1)
              For tableindex = 1 To tablecount
                   tablename = ph.getdata_cn(1, CLng(tableindex), "tname")
                   If tablename <> "SYSUSERPERM" Then
                         tablestatus = ph.sqlselect(2, "SELECT * FROM " & tablename)
                         tableinfo.WriteLine("Table : " & tablename)
                         If (tablestatus = 0 Or tablestatus = 2) Then
                                colcount = ph.getcolcount(2)
                                For colindex = 1 To colcount
                                      colname = ph.getcolname(2, CLng(colindex))
                                      coltype = ph.getcoltype(2, Clng(colindex))
                                      tableinfo.WriteLine("      " & CStr(colindex) & " : " & colname & " : " & coltype)
                                Next
                         Else
                                enumtables = "success with errors"
                                tableinfo.WriteLine(" &nb sp;    Error " & CStr(tablestatus) & " opening " & tablename)
                         End If
                         tableinfo.WriteBlankLines(3)
                         ph.sqldestroy(2)
                   End If
              Next
              ph.sqldestroy(1)
      End If
      tableinfo.Close
      Set tableinfo = Nothing
 End Function
         device Newbie
           | Posted: February 01 2010 at 16:32 | IP Logged
A "&nb sp;" snuck in there when the message was converted to HTML which should be removed.
 D
           | Posted: February 02 2010 at 09:40 | IP Logged
I have connected to the PH database with Access over ODBC.
 Wow, I had no idea there were so many tables!  I now have
 the information I need to start playing.
 You script does look useful.  I think I will be able to use
 it in other situations like this as well (outside of PH).
         device Newbie
           | Posted: February 02 2010 at 13:59 | IP Logged
Actually the VBScript assumes it is running in PH. I wrote this a while back to begin to become familiar with VBScript, SQL and PH. I do a fair amount of SQL using VBScript in servicing PH events. If you need to manipulate the tables outside of PH and you have and are familiar with Access then that probably is the way to go. Have fun,
 D
