Subject Topic: PH 2.2 beta3-3 Crashing daily Post ReplyPost New Topic
Posted: June 30 2022 at 10:28 | IP Logged Quote GadgetGuy
gg102-
I do the same thing you do for the Event Log.  I am talking about the pwrhome.db (data base) file.  I make changes often enough that I want an accurate record of the the db state, especially if I need to restore back to an earlier version.
Accordingly I run the "ph_backupdb()" function every night and name the file with a timestamp (for example) "ph-220630.db".... representing the database on 2022 June 30.
To use that file I rename it "pwrhome.db" and replace the current file of the same name in the powerhome/database folder.
Bottom line.... my daily timestamped db backups need to be trimmed or the files would grow into a collection of way too many.
That is what my trim code is for.  gadgetGuy
gg102
Posted: June 30 2022 at 10:36 | IP Logged Quote gg102
GadgetGuy:
Ah yes. I do the same thing. To prevent the overgrowth of database files (what you're describing), I simply use the day of the month as part of the name,
thus I have 30 back databases. Only needed it once. Once is enough.
Great minds think alike!
Posted: July 03 2022 at 12:42 | IP Logged Quote GadgetGuy
Discovered probably PH crash reason.
Bank 0 of my Memory array has consistent errors in bits 65 and 40.
I replaced all Memory cards but the errors still remained so assuming it is a CPU or memory driver IC issue.
Good excuse to order a new super duper Gaming Tower which I will use for my Video Production efforts and relegate my prior computer to being the PH Server.
Hopefully this will restore the kinds of reliable PH execution I have experienced for a very long time.
Posted: July 04 2022 at 07:18 | IP Logged Quote TonyNo
How did you find that out?
Posted: July 04 2022 at 07:42 | IP Logged Quote GadgetGuy
All of a sudden PH was crashing regularly with the same
configuration that has been solid for over a year. The
Windows Media Player (WMP) quit playing ANY files but
Streamed OK.
Tried to reinstall WMP but all attempts failed. Then
tried a Windows 10 re-install and it failed twice.
At that point figured I had a hardware issue. Ran HP
provided diagnostics and it immediately discovered the
Memory BankA in slot 0 was bad. But that only gave that
simple error message, so downloaded "MemTest86+"
   www.memtest.org/
which extensively tests RAM (outside of the Windows OS
via a boot USB software load).
The Ap displays a comprehensive failure report including
which bytes and bits are bad.
Edited by GadgetGuy - July 04 2022 at 07:44
Posted: July 06 2022 at 06:50 | IP Logged Quote TonyNo
<< Prev Page of 2
