Subject Topic: PH Socket plugin Problems Post ReplyPost New Topic
PCarp
Posted: February 27 2014 at 14:44 | IP Logged Quote PCarp
I am using the PH Socket plugin to get information from a device that has information about the electrical usage in my home.
Socket plugin setup info: PH_Socket.phsocket 10.0.1.60:8002
I am reading the information with: ph_getvar_s(2,5)
The problem that I have is when the trigger fires it fires twice and runs two incidences of the macro that reads the ascii information . If I disable the trigger in the macro and only one incidence of the macro runs then the information is not complete. This causes a problem with the formula thatI am using. If I don't disable the trigger in the macro it will fire twice and will run the macro each time. The second time the macro is run the information is complete.
The file is over 800 characters long and the info that I need is toward the back of the file. For a temporary solution I use the ph_killmacrowait ("GEM") in the macro.
Thanks Paul
Back to Top View PCarp's Profile Search for other posts by PCarp
Posted: March 03 2014 at 10:36 | IP Logged Quote dhoward
Paul,
I took a look at the source code and then best I can come up with is that since the read info is so long, its firing the socket twice to get the message in a couple of chunks. However, I would expect the first time the macro is run, the [TEMP5] variable would contain the first chunk and the second time the macro is run, the [TEMP5] variable contains the second chunk (and contains the data of interest to you). Based upon your description though, it sounds as if the first time the macro runs, you get the first chunk and the second time the macro runs you get the complete message including the first chunk.
In any event, assuming the complete data is roughly the same length with each call, I would think the best way to handle this is to check the length of [TEMP5] in the Boolean formula of the trigger.
Say the first time the macro runs, you get 600 bytes of data. The second time the macro runs, you get 850 bytes of data. You could place this formula in the Boolean field:
len(ph_getvar_s(2,5)) > 800
and the trigger will only execute the macro if the length of the data is over 800 bytes. You could also do variations of this formula by searching for a particular unique string portion that would only occur in the complete message.
I think this would give you cleaner results than killing the macro.
Hope this helps and let me know how it goes.
PCarp
Posted: March 03 2014 at 15:52 | IP Logged Quote PCarp
That did help. I still never get the entire file but the tail end of the file is always there.
The information that I need is towards the end of the file so I am good to go.
