Subject Topic: Database where used - no useful info? Post ReplyPost New Topic
jeffw_00
Posted: February 06 2021 at 12:28 | IP Logged Quote jeffw_00
Hi - I'm using 2.1.5d   I thought Reports -> Database where used
would tell me where a string is used, but recently it doesn't provide
any useful information- it just lists the string over and over as MACRO
DETAIL and SEQUENCE <#>   Am I missing something silly? I
thought it used to tell you all the Macros, triggers, etc, where a string
was used.   Thanks!
Edited by jeffw_00 - February 06 2021 at 12:28
Posted: February 06 2021 at 12:58 | IP Logged Quote dhoward
Jeff,
It should be working (even in 2.1.5d). What are you using for the search string?
Let me know and I can provide more info.
jeffw_00
Posted: February 06 2021 at 13:30 | IP Logged Quote jeffw_00
Thanks Dave - it's on Macro Names that I'm striking out. (maybe it
doesn't search formulas?)
Posted: February 07 2021 at 18:32 | IP Logged Quote dhoward
Not sure what the problem would be. Are you using wilcards? Essentially, ALL string fields including ID, Description, and Formulas
should be searched.
If you have a macro called MYMACRO, you should use a search string of %MYMACRO% and it should find it in any formula.
jeffw_00
Posted: February 07 2021 at 18:36 | IP Logged Quote jeffw_00
Did not know about the %<string>% syntax - that works! thanks!
