lizaoreo Groupie
Posted: August 26 2013 at 14:23 | IP Logged
Okay, I got my camera set up on the back porch and triggers for motion configured in Blue Iris. I made a macro in PH to turn the back porch light on for 10 minutes (IE, someone pulled up or opened the door) and setup Blue Iris to run the macro when it detects motion. After 10 minutes, it turns off the light.
The problem I discovered this week (like 2 days after I set it up) is that when someone is unloading the car or just doing something outside that takes longer than 10 minutes, they trigger the macro (Yay), but they trigger it several times, so then the light comes on, then starts turning off randomly as the 10 minute timers run out.
Is there a way I can do a smart timer so that every time the macro triggers after the initial time it just resets the timer rather than making new ones?
Posted: August 26 2013 at 15:28 | IP Logged
The way I handle this is to usually do a Jump or Goto Label as the first line of a macro. Something like:
10 Goto Label if(ph_ismacrowaiting("YOURMACROID") = 0,"CONTINUE","")
20 Formula Immediate ph_extendmacrowait("YOURMACROID",10 * 60,0)
30 End Macro
40 Label CONTINUE
50 ...
The above was from memory so may need to be checked for accuracy.
lizaoreo Groupie
Posted: August 26 2013 at 15:34 | IP Logged
Aha, there are more formulas for macro commands, that was kind of my first path of thought, but I couldn't find the right formula commands.
Thanks Dave
