| Posted: February 19 2005 at 16:06 | IP Logged
Any way to support ph_playsound and ph_tts in DCC? This would be great for distributed announcements and such.
| Posted: February 21 2005 at 13:37 | IP Logged
Well ph_playsound is definately no problem...not sure why I didnt include it in the first place. TTS on the other hand is a little more involved and would require the user to install the TTS modules. I'll look into it though since it would be really handy for remote TTS capabilities.
I'll release a new version of the DCC shortly after the next beta.
| Posted: February 21 2005 at 20:32 | IP Logged
Great, thanks Dave!
Tony
| Posted: July 12 2005 at 22:59 | IP Logged
OK, what about an OSD function? Pop up messages and such, maybe even use graphics?
| Posted: July 18 2005 at 15:29 | IP Logged
Are you talking about an OSD for the DCC? If so, would PowerHome need to process the returns from these messages?
Would the graphics be located on the DCC machine or the PowerHome machine?
| Posted: July 18 2005 at 16:12 | IP Logged
Yup. An OSD for DCC. Processing returns would not be necessary.
As far as the graphics go, I could live without them, but it would be cool if they could live on the PH machine.
I've done some research and only come up with one available option (YAC). This works, but the options need to be set in the registry!
| Posted: August 10 2005 at 21:30 | IP Logged
Im trying to think of something generic and Im thinking about using the IE web browser control. Basically, you could cause the DCC to open a window (you control size and position) without a toolbar, etc. that would then open a page (that you passed in the function) on the PowerHome server. That way, the graphics and even intelligence could reside on the PowerHome server and the page could be as simple or detailed as necessar.
Do you think this would server your purpose?
krommetje Super User
| Posted: August 11 2005 at 04:26 | IP Logged
Hi Dave...
That would open a lot of possibilities....
Edited by krommetje
| Posted: August 11 2005 at 08:56 | IP Logged
I think that would do nicely!
| Posted: August 11 2005 at 20:09 | IP Logged
Quote:
| Im thinking about using the IE web browser control |
Does that need IE, or can it be just the default browser?
| Posted: August 12 2005 at 13:50 | IP Logged
The Microsoft Web Browser control is built into the OS, but uses IE. It's the same control that appears in the PowerHome client as the "Web Center".
