Posted: March 22 2006 at 02:17 | IP Logged
zero, welcome to PowerHome!
It depends what kind of support you're talking about. PowerHome does currently support the 2814UB as an Insteon PLC controller. It does not make use of it's Timer or download features.
This device is no different than a 2414U except that it lacks a pass-thru outlet. You can download the Timer software and use it with any of the current Insteon PLC devices.
Currently, PowerHome does not make use of the extended downloading features of any of it's supported controllers.
If you're looking to use the 2814UB as an Insteon interface into PowerHome (PowerHome is running continously and is actually doing the decisions and control), then the support is already there. If you're wanting to download timers and macros into the PLC and disconnect the PC, then PowerHome does not do this.
