Subject Topic: RF Trials and Tribulations Post ReplyPost New Topic
Manny
Posted: July 26 2006 at 18:01 | IP Logged Quote Manny
Not exactly a bug, but hopefully can stay on the radar(Dave sent me an email awhile back...):
Just posting this in case it helps others.
Something/someone near my house is spouting out all kinds of RF that is triggering PH. I've narrowed it down to 2 unused letters (at least today), so hopefully that should allow me the continued use of my MR26A.
Eventually it creates a critical error by trying to address unit code 0:
PowerHome Version: 1.03.4.7        &nbs p;         &nbs p;
Error Number: 3           ;           ;
Error Message: Array boundary exceeded at line 17 in function f_x10transaction of object uo_function.
Window: uo_function        & nbsp;         & nbsp;
Object: uo_function        & nbsp;         & nbsp;
Event: f_x10transaction       &n bsp;         &n bsp;
Line: 17         &nbs p;515
7/26/2006 11:10:48:321     4    ;  PowerLinc USB (1132U) Controller X10-1 transmission of House code: M, Unit Code: 0           ;514
7/26/2006 11:10:48:117     3    ;  Incoming X-10 RF received on MR26A Controller X10-2. Housecode: M Command: All Lights On         &nbs p;513
If it turns out I can no longer use the MR26A Controller I'm considering trying out the Black and Decker FreeWire Motion detectors as these are x10 compatible products and seem to be using secure RF (at least the 1 remote and receiver I have is.
Snippet below:
Incoming X-10 RF received on MR26A Controller X10-2. Housecode: L Unit: 9 Command: On
Incoming X-10 RF received on MR26A Controller X10-2. Housecode: O Unit: 9 Command: On
PowerLinc USB (1132U) Controller X10-1 transmission of House code: M, Command: On
PowerLinc USB (1132U) Controller X10-1 transmission of House code: M, Unit Code: 3
Incoming X-10 RF received on MR26A Controller X10-2. Housecode: M Unit: 3 Command: On
Incoming X-10 RF received on MR26A Controller X10-2. Housecode: H Unit: 1 Command: On
Incoming X-10 RF received on MR26A Controller X10-2. Housecode: J Unit: 12 Command: Off
Incoming X-10 RF received on MR26A Controller X10-2. Housecode: B Unit: 9 Command: On
PowerLinc USB (1132U) Controller X10-1 transmission of House code: M, Command: Off
PowerLinc USB (1132U) Controller X10-1 transmission of House code: M, Unit Code: 7
Incoming X-10 RF received on MR26A Controller X10-2. Housecode: M Unit: 7 Command: Off
Incoming X-10 RF received on MR26A Controller X10-2. Housecode: G Unit: 11 Command: On
Incoming X-10 RF received on MR26A Controller X10-2. Housecode: N Unit: 8 Command: Off
Incoming X-10 RF received on MR26A Controller X10-2. Housecode: I Unit: 1 Command: On
Incoming X-10 RF received on MR26A Controller X10-2. Housecode: D Unit: 3 Command: On
PowerLinc USB (1132U) Controller X10-1 transmission of House code: C, Command: On
PowerLinc USB (1132U) Controller X10-1 transmission of House code: C, Unit Code: 16
Incoming X-10 RF received on MR26A Controller X10-2. Housecode: C Unit: 16 Command: On
Incoming X-10 RF received on MR26A Controller X10-2. Housecode: J Unit: 9 Command: On
Incoming X-10 RF received on MR26A Controller X10-2. Housecode: A Unit: 1 Command: On
PowerLinc USB (1132U) Controller X10-1 transmission of House code: C, Command: Off
PowerLinc USB (1132U) Controller X10-1 transmission of House code: C, Unit Code: 8
Incoming X-10 RF received on MR26A Controller X10-2. Housecode: C Unit: 8 Command: Off
Incoming X-10 RF received on MR26A Controller X10-2. Housecode: N Unit: 1 Command: On
PowerLinc USB (1132U) Controller X10-1 transmission of House code: M, Unit Code: 1
Incoming X-10 RF received on MR26A Controller X10-2. Housecode: M Unit: 1 Command: On
Incoming X-10 RF received on MR26A Controller X10-2. Housecode: F Unit: 11 Command: On
Incoming X-10 RF received on MR26A Controller X10-2. Housecode: J Unit: 16 Command: Off
Incoming X-10 RF received on MR26A Controller X10-2. Housecode: G Unit: 16 Command: Off
Incoming X-10 RF received on MR26A Controller X10-2. Housecode: A Unit: 11 Command: Off
Incoming X-10 RF received on MR26A Controller X10-2. Housecode: N Command: Bright
Incoming X-10 RF received on MR26A Controller X10-2. Housecode: I Unit: 5 Command: On
Incoming X-10 RF received on MR26A Controller X10-2. Housecode: A Unit: 4 Command: Off
PowerLinc USB (1132U) Controller X10-1 transmission of House code: M, Unit Code: 13
Incoming X-10 RF received on MR26A Controller X10-2. Housecode: M Unit: 13 Command: On
Incoming X-10 RF received on MR26A Controller X10-2. Housecode: K Unit: 10 Command: Off
Back to Top View Manny's Profile Search for other posts by Manny
Posted: August 02 2006 at 23:30 | IP Logged Quote dhoward
Manny,
The invalid X10 unitcodes are now checked for and will no longer cause a critical error in the next beta.
