Dracol1ch Newbie
| Posted: September 21 2006 at 17:54 | IP Logged
I have a KPLv2. Unfortunately I can't get the KPL util to work it just says it can't communicate. Also for what ever reason in my Groups by Controller section the KPL is listed twice. The first showing groups 1,3,4,5,6 and the second listing showing more of group 6 (it's a large all off group).
Any ideas?
Plano_Mike Newbie
| Posted: September 21 2006 at 19:49 | IP Logged
I'd suggest opening the SDM window (click the T icon in your task bar)and see if you spot any error messages or no acknowledge messages. Note that the data conversations you see there will not be human friendly. If you don't have any experience with that try searching this board for SDM and you should get some clues.
__________________ Mike
Dracol1ch Newbie
| Posted: September 23 2006 at 18:58 | IP Logged
Currently I can now use the KPL editor for no apparent reason. I still do have the KPL listed twice in groups, however, which worries me.
I did notice that I have near constant Insteon traffic in those logs when Powerhome is loaded. Can anyone tell me what's going on in the following log section? It seems to be the same messages repeated over and over. I highlight this one in particular because it includes a nakmsg which I assume is no-acknowledge. Keep in mind there should have been no Insteon traffic at this time. I had no switches being operated and no timers or other bits running.
Secondly, I don't seem to be able to control the local load on my KPL through PowerHome. If I send a command to turn on the KPL it reports the KPL is on but the light is still out.
9/23/2006 3:52:36 PM:ackmsg=06 7F 7A 07 8C 78 22 2B 45
ui:sendinsteonraw=00 00 00 06 7F 7A 05 28 0F
si:00 00 00 06 7F 7A 05 28 0F
PLC:sendinsteonraw=True
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=05
9/23/2006 3:52:53 PM:nakmsg
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=04
PLC:receiveinsteonraw=04 06 7F 7A 07 8C 78 27 28 0F
9/23/2006 3:52:55 PM:ackmsg=06 7F 7A 07 8C 78 27 28 0F
PLC:eventraw=03
ui:sendinsteonraw=00 00 00 06 7F 7A 05 2B 60
si:00 00 00 06 7F 7A 05 2B 60
Edited by Dracol1ch - September 25 2006 at 14:21
