| Posted: August 10 2003 at 21:46 | IP Logged
Manny,
I checked out the links and thats the RF protocol for the Ninja, but not the communication protocol for the CM19A :-(
However, on the same site, you can find plans to build an IR to RF converter and a program that will output the Ninja RF protocol as IR codes to a RedRat2.
I have actually purchased all of the components and have been planning to build the IR to RF converter since I currently use a RedRat2 with PowerHome. I plan on this being my workaround to control my Ninja. Alas, I have not had a chance to build it since Ive been too busy working on the next release of PowerHome.
If you want to check it out, the link to the IR to RF converter is here: http://www.laser.com/dhouston/ir2rf.htm and the link to the software to generate RedRat2 compatible IR codes is here: http://www.laser.com/dhouston/codegen.htm
Skoegler,
As Tony suggested, I would recommend the CM11A for sending powerline X-10 and the MR26A for receiving RF X-10. When the next version is released, you can use the RS-232 version of the PowerLinc and the WGLDesigns W800 or W800RF32.
