Subject Topic: Data entry at website Post ReplyPost New Topic
krommetje
Posted: January 08 2005 at 03:28 | IP Logged Quote krommetje
Hi,
yesterday I entered a timed event from the webserver, after clicking the Update button, the date changed to 18-08-1901 despite the fast that 2005 was entered.... is this a bug ?
Posted: January 08 2005 at 09:58 | IP Logged Quote TonyNo
I just tried it and saw no error. Do you recall the date and time you used?
Posted: January 08 2005 at 10:30 | IP Logged Quote dhoward
Most likely it was just the format you used. Date/times should be entered like: yyyy-mm-dd hh:mm:ss. Other formats will sometimes work, but this is the default standard and the most reliable.
krommetje
Posted: January 09 2005 at 02:53 | IP Logged Quote krommetje
I entered 2005-01-14 08:00:00 so the format should be correct, I was able to delete the bad-entry at the server itself, not at the remote site. Then I entered another one which was correct....so no harm done.
Posted: January 09 2005 at 18:07 | IP Logged Quote dhoward
Peter,
When you enter 2005-01-14 08:00:00 from the web, does it blow up all the time, or just the one time?
krommetje
Posted: January 11 2005 at 05:57 | IP Logged Quote krommetje
I tried it a second time, and that worked well. Also I have been programming some formulas into the timed events and up until now it worked fine.... I have been browsing through the temp. internet files. The only error I could find was an error in writing to a tmp-file, but this is browser-spec. Maybe Firefox is not as flawless as specified.
