Subject Topic: ph_run and Win10 Pro Post ReplyPost New Topic
Posted: November 24 2018 at 17:40 | IP Logged Quote smarty
EDIT #2 - issue solved - It seems that Win10 is much more finicky than Win7 with respect to path execution and environmental (path) variables. Once I put a "pause" into my .bat and .cmd files (to see what was flashing on the screen), I could see that the issue was with the path execution; not a PH issue at all.
I am switching operating systems from Win7x32 to Win10x64 Pro (also upgrading hardware).
Most things have been going smoothly....only real issue is that "ph_run()" does not seem to launch .bat .cmd or curl type files.
I double checked to make sure:
-UAC is off for EVERYTING
-PH is running with "elevated privileges", i.e. is running as an administrator.
Other than these two items, I am having trouble figuring out what within Win10Pro x64 is blocking me.
EDIT - also tried turning off DEFENDER and Firewall...still no luck.
Edited by smarty - November 25 2018 at 13:33
Posted: December 06 2018 at 17:42 | IP Logged Quote dhoward
Steve,
Appreciate the update and edit. I'll have to remember this when I upgrade my system to Win 10.
Glad to hear you got it figured out though.
